KS66
Message 1 of 12
ISP configuration
Hello
My box tells me I cannot get my on demand channels etc as I am not connected to the Internet.  However, my box settings say that I am.  My bt hub manager also says it thinks it is connected via Ethernet cable to the box too.
I had a very long phone conversation last night with a technical adviser who got me to reset factory settings etc. Have also rebooted the router multiple times, unplugged and replugged everything.
Under 'system information - software versions', I dont appear to have any number in the 'isp configuration' section.  Should I?
I was upgraded to infinity last week but otherwise, nothing has changed with my to setup.
Thanks for any tips help etc....
kath
11 REPLIES 11
zulu17
Distinguished Guru
Distinguished Guru
Message 2 of 12
Re: ISP configuration
Yes there should be a value set for the ISP configuration. I believe Youview uses the ISP configuaration to determine which on demand players  to display and what IPTV channels to include in your boxes EPG.
KS66
Message 3 of 12
So how do I go about finding the correct figure, and then adding it - especially as the box thinks it's not actually connected to Internet?
zulu17
Distinguished Guru
Distinguished Guru
Message 4 of 12
Do you know if there was an ISP configuration value before the Youview box was reset to factory settings ?
If so then possibly the Youview box hasn't gone thru  the complete  setup process after a factory reset . Try a 8 second box reset (press box power burtton for 8 seconds)  , try (Youview>Settings>Device Management) update software and update on demand players.
Which Youview box do you have  and which home hub  ?
The Youview box is reporting connected - do you notice anything unusual about any of the details of the dns and ip address that is displayed ?
KS66
Message 5 of 12
Sorry, don't know if ISP configuration value was there prior to factory reset.
Have just tried 8 second reboot  again, and it didn't change anything. Also says has latest software and on demand players
i have humax DTRT1000
under system information (where the ISP configuration detail is blank), it also says 'software version - last updated; never'. Am assuming this is because of factory reset last night.
The network connection status shows IP address and router info to be the exact same as details in home hub 5 router manager. I have tried switching wired connection to manual and back to auto - and it still comes back saying is connected.
This is  the first time I have tried using the television since the infinity upgrade - could that have done something to the ISP value?   (know they had to expand capacity on exchange for me to get it)
zulu17
Distinguished Guru
Distinguished Guru
Message 6 of 12
Can you confirm what software versions are currently on the box ?
KS66
Message 7 of 12
Manufacturer software - 21.50.50
component software - 2.9.34
platform configuration - 1393
ISP configuration -
zulu17
Distinguished Guru
Distinguished Guru
Message 8 of 12
I have requested moderator assistence for you -
KS66
Message 9 of 12
Thanks for that. K
RobbieMac
Moderator
Moderator
Message 10 of 12
Hi @KS66
Welcome to the community forum and thanks for your post!
I can help check everything is ok from our end.  Click on my username here >> RobbieMac << and you'll see our contact link on the left hand side underneath my profile picture.
Cheers,
Robbie
