Hi,
I was looking for some advice please.
I purchased the Home Wifi triple pack (1st gen) on Tuesday, got them set up but not getting the speeds I was expecting.
Router Set up:
Disc set up:
House
I appear to be getting close to full speed on disc one via Wi-Fi, with ok speeds on 2-3 - but I am trying to improve these if possible, current speed tests give anything around 120mb on my phone via Wi-Fi on disc 2 and around 90-100mb on my computer on disc 3 via Ethernet and the same on my phone via Wi-Fi.
On my computer, which is connected to disc 3 via Ethernet, I can clearly see that my computer is negotiating with the disc at 1.0 Gpbs so it isn’t limited to 100mb.
Tests so far:
Overview page shows all discs having a ‘Good’ connection (even for disc one connected via Ethernet to the router). Looking on the BT app it shows the discs as all being in an ‘Excellent’ location.
Disc Status page
Disc 1
Disc 2
Disc 3
I’m not sure if there’s anything else I can try before returning these, but any other suggestions would be appreciated.
Jason
Jason,
How did you program connection disc to hub to be ethernet rather than wi fi?
My disc is connected ethernet as an experiment but some devices use the ethernet and others use WI fi to connect hub to disc assuming you can believe what the app tells you or what you can see when you log on to hub.
