Message 1 of 23
Improve wifi speed/connectivity options?
We live remotely and suffer with very poor internet speeds (current provider is BT) - what products can you recommend, cheaper the better, to try and improve connectivity, even if only marginally?
22 REPLIES 22
Message 2 of 23
Re: Improve wifi speed/connectivity options?
@marcuspos
Check to see what is available.
Please edit out your phone number before you post the results.
Message 3 of 23
Don’t really know what to look at/for when our speed rarely gets above 2mbps!?
Message 4 of 23
can you post adslchecker results here
Message 5 of 23
Message 6 of 23
unfortunately you must be so remote that even though cab 1 has FTTC available you are to far from the cabinet to be able to get FTTC
Message 7 of 23
@marcuspos
Those results will be the same for all providers that use the Openreach network. If you have a number of close neighbours who are getting slow speed, then perhaps the Openreach Community Partnership Scheme may be worth trying.
Also see https://www.bt.com/broadband/USO
Message 8 of 23
Yes we live VERY remote! What does FTTC mean exactly please? What can I try, will no type of extender or booster help?
Message 9 of 23
FTTC delivers faster broadband from enabled cabinets, but you are too far away from the cabinet. Nothing you can add at your end, will improve the connection speed of 1Mbs.
Try the BT USO link.
Message 10 of 23
No immediate neighbours and no BT plans for any lines upgrades…
