Newbie
Message 1 of 4
Inconsistent connection and reduced speeds.
I have noticed over the last few weeks that my internet connection has been really poor. I am based in Central London and I remeber there being issues ever around the times of the storms but they seem to have been fixed.
I am finding that I am getting a lot of "Resolving host" messages in Chrome where some sites seem to load ok and then others take a while. Sometimes the internet drops out completely for a few minutes.
I have tried restarting the HomeHub router without any luck and I am getting a bit annoyed now because we use the internet within the home for business as well.
Just run a speed test and the results are pretty poor. http://www.speedtest.net/my-result/3720853977
ADSL Line Status
Connection Information
Line state:Connected
Connection time:0 days, 04:20:22
Downstream:2.492 Mbps
Upstream:975.8 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Fast
Noise margin (Down/Up):9.0 dB / 6.3 dB
Line attenuation (Down/Up):49.9 dB / 29.9 dB
Output power (Down/Up):18.1 dBm / 12.7 dBm
FEC Events (Down/Up):0 / 0
CRC Events (Down/Up):61904 / 1044
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):58971 / 1196
Error Seconds (Local/Remote):17637 / 610
3 REPLIES 3
Message 2 of 4
Re: Inconsistent connection and reduced speeds.
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
Newbie
Message 3 of 4
Hi. I have run through the guide and the information relating to the connection is in the first post.
Another poor connection this morning, some sites are partially loading and others are looking for "Resolving Host" before loading.
BLOCKED 1 more packets (because of Remote administration)
09:30:18, 29 Aug.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 192.42.130.15->86.174.105.236 on ppp0)
09:20:30, 29 Aug.BLOCKED 1 more packets (because of Remote administration)
09:20:29, 29 Aug.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 192.42.130.15->86.174.105.236 on ppp0)
09:10:38, 29 Aug.BLOCKED 1 more packets (because of Remote administration)
09:10:36, 29 Aug.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 192.42.130.15->86.174.105.236 on ppp0)
09:06:06, 29 Aug.IN: BLOCK [16] Remote administration (TCP [218.77.79.43]:42965->[86.174.105.236]:443 on ppp0)
09:00:49, 29 Aug.BLOCKED 1 more packets (because of Remote administration)
09:00:48, 29 Aug.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 192.42.130.15->86.174.105.236 on ppp0)
08:54:40, 29 Aug.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 86.174.105.236->17.172.100.8 on ppp0)
08:50:54, 29 Aug.BLOCKED 1 more packets (because of Remote administration)
08:50:53, 29 Aug.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 192.42.130.15->86.174.105.236 on ppp0)
08:41:32, 29 Aug.IN: BLOCK [16] Remote administration (TCP [122.228.207.193]:38071->[86.174.105.236]:22 on ppp0)
08:40:24, 29 Aug.BLOCKED 1 more packets (because of Remote administration)
08:40:23, 29 Aug.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 192.42.130.15->86.174.105.236 on ppp0)
08:30:28, 29 Aug.BLOCKED 1 more packets (because of Remote administration)
08:30:27, 29 Aug.IN: BLOCK [16] Remote administration (ICMP type 8 code 0 192.42.130.15->86.174.105.236 on ppp0)
08:27:23, 29 Aug.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 86.174.105.236->17.110.240.13 on ppp0)
08:26:17, 29 Aug.BLOCKED 1 more packets (because of ICMP replay)
08:26:16, 29 Aug.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 86.174.105.236->64.233.167.84 on ppp0)
08:26:15, 29 Aug.BLOCKED 1 more packets (because of ICMP replay)
08:26:13, 29 Aug.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 86.174.105.236->64.233.167.84 on ppp0)
08:26:08, 29 Aug.BLOCKED 1 more packets (because of ICMP replay)
08:26:07, 29 Aug.OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 86.174.105.236->74.125.230.243 on ppp0)
08:26:06, 29 Aug.BLOCKED 1 more packets (because of ICMP replay)
Message 4 of 4
For us to help you further can you please post back the results of the tests asked for
