Message 11 of 36
Re: Inconsistent speed
Thanks imj missed that 😞
Message 12 of 36
I'm currently connected to our master socket, and when testing on our test socket the speed does not increase nor does the ping issue go away.
Message 13 of 36
can you post a tracerert to BBC.co.uk
Message 14 of 36
Bear in mind this was taken when the internet was working normally, I will try run a tracert during a slow period when next available.
tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.244.20]
over a maximum of 30 hops:
1 4 ms 7 ms 2 ms 192.168.1.1
2 23 ms 185 ms 24 ms 217.47.112.250
3 24 ms 35 ms 54 ms 217.47.130.193
4 27 ms 26 ms 25 ms 213.1.69.110
5 29 ms 26 ms 37 ms 31.55.164.103
6 28 ms 26 ms 27 ms 31.55.164.219
7 26 ms 25 ms 28 ms 31.55.164.109
8 74 ms 40 ms 28 ms 109.159.248.193
9 32 ms 32 ms 32 ms 109.159.252.212
10 35 ms 36 ms 35 ms peer2-xe3-2-0.telehouse.ukcore.bt.net [109.159.2
54.221]
11 36 ms 36 ms 35 ms 194.74.65.42
12 * * * Request timed out.
13 * * * Request timed out.
14 33 ms 50 ms 40 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
15 36 ms 40 ms 37 ms 132.185.255.149
16 32 ms 32 ms 31 ms fmt-vip71.telhc.bbc.co.uk [212.58.244.20]
Trace complete.
Message 15 of 36
This is the tracert taken when our internet is having the slow period. Judging by the results it's caused by our connection to the ISP right?
tracert bbc.co.uk
1 2 ms 2 ms 2 ms 192.168.1.1
2 2538 ms 3279 ms * 217.47.112.250
3 * * 2899 ms 217.47.130.193
4 2711 ms * * 213.1.69.110
5 471 ms 436 ms 460 ms 31.55.164.103
6 2848 ms 2127 ms 471 ms 31.55.164.219
7 1386 ms 1998 ms 3008 ms 31.55.164.109
8 800 ms 972 ms 1100 ms 109.159.248.193
9 2804 ms 2901 ms 1641 ms 109.159.248.50
10 1888 ms 1414 ms 1277 ms peer2-xe8-1-1.telehouse.ukcore.bt.net [109.159.2
55.103]
11 1798 ms 1531 ms 1479 ms 194.74.65.42
14 2277 ms 1812 ms 1356 ms ae0.er01.telhc.bbc.co.uk [132.185.254.109]
15 731 ms 965 ms 1176 ms 132.185.255.149
16 579 ms 658 ms 698 ms fmt-vip71.telhc.bbc.co.uk [212.58.244.20]
Trace complete.
Message 16 of 36
looks like a possible congestion issue could you also post the further diagnostics part of the speedtest when the connection slows we can then get the forum mods to intervene
Message 17 of 36
This was taken during a slow period, not the worst results I've seen but I hope it's enough to show something . . . bear in mind this isn't the slowest it can be, when it's really at it's worst I can't connect to the wholesale page.
 Download speedachieved during the test was - 0.83 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :6.3 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 5.5 Mbps
Message 18 of 36
Any help with the congestion?
Message 19 of 36
very slow but still just above the wholesale minimum i think the mods may be able to help
Message 20 of 36
Once the Forum Mods have read your post they will post an invite here, once you reply to them they will take personal ownership of the problem until resolved.
Do not send them a Personal Message as this is the incorrect contact method and cannot be properly tracked also the mod contacted may not be on shift for sometime and this will delay your help.
The forum mods normally reply within 3/5 working days after you have contacted them via their contact form
They will contact you personally by email or phone.
