Message 1 of 5
Incorrect address with Openreach
I have just migrated my BB/landline from John Lewis (Plusnet) to Plusnet. In the process my address has been amended and is now incorrect. Plusnet tell me that they use the details supplied by Openreach, so only Openreach can amend them.
Can't find a way of talking to Openreach about this. Can anyone help, please?
Many thanks
4 REPLIES 4
Message 2 of 5
Re: Incorrect address with Openreach
only your ISP PLusnet can get openreach to correct your address  plusnet need to raise an ORDI with openreach
there is nothing BT Retail community can do to help
Message 3 of 5
Your provider should be able to raise this to Openreach. Nothing anyone here or in BT can help you with.
Message 4 of 5
Many thanks, DS. I will tell Plusnet!
Message 5 of 5
Yes, you would have thought so, wouldn't you! They told me to phone Openreach - sigh!
Many thanks for your prompt reply.
