Message 1 of 8
Incredibly High Latency and Low Download Speed
Been having a problem for about a week and a half now regarding the speed and the latency of my connection. We have always had problems but this is beginning to get a bit frustrating now.
One half of the problem is that the latency is extremely high, it is averaging around 1100ms between the homehub and the exchange in milton keynes a few miles down the road. The other half of the problem is that the actual speeds for both downloading and uploading are incredibly low. Averaging around 0.40megabits per second download and 0.02megabits per second for upload. Before this problem occured we were averaging around 7.50megabits per second and the upload speed was scaled up proportionally aswell.
I have been using speedtest.net to test the connection and then have done some trace routes to www.google.com and the issue is definitly between the homehub and the exchange in milton keynes. There are some trace routes below:
Tracing route to www.l.google.com [74.125.230.146]
over a maximum of 30 hops:
  1     1 ms     4 ms     1 ms  api.home [192.168.1.1]
  2   1271 ms   1198 ms   *  esr1.miltonkeynes3.broadband.bt.net [217.47.74.140]
  3  1534 ms  1184 ms  921 ms  217.47.74.125
  4  1392 ms  1449 ms  968 ms  213.1.69.106
  5  1611 ms  1148 ms   986 ms  217.41.222.62
  6   1343 ms   1417 ms   1167 ms  217.41.222.182
  7  1195 ms   1252 ms   1165 ms  acc2-10GigE-0-0-0-6.bm.21cn-ipp.bt.net [109.159.248.210]
  8   1454 ms   1687 ms   1456 ms  core2-te-0-2-5-0.ealing.ukcore.bt.net [109.159.248.130]
  9   1518 ms   1687 ms  948 ms  core4te-0-1-2-0.telehouse.ukcore.bt.net [109.159.254.46]
 10   1125 ms   1468 ms   1279 ms  195.99.126.58
 11   831 ms   1310 ms   1341 ms  209.85.255.175
 12   974 ms   912 ms   1259 ms  209.85.251.202
 13   786ms  652 ms   1058 ms  74.125.230.146
Trace complete.  1     1 ms     4 ms     1 ms  api.home [192.168.1.1]
  2   770 ms   659 ms   632 ms  esr1.miltonkeynes3.broadband.bt.net [217.47.74.140]
  3  1231 ms  1248 ms  1151 ms  217.47.74.125
  4  1203 ms  1006 ms  1207 ms  213.1.69.106
  5  1130 ms  1038 ms   976 ms  217.41.222.62
  6   996 ms   672 ms   853 ms  217.41.222.182
  7  1174 ms   884 ms   749 ms  acc2-10GigE-0-0-0-6.bm.21cn-ipp.bt.net [109.159.248.210]
  8   872 ms   974 ms   949 ms  core2-te-0-2-5-0.ealing.ukcore.bt.net [109.159.248.130]
  9   963 ms   935 ms  1097 ms  core4te-0-1-2-0.telehouse.ukcore.bt.net [109.159.254.46]
 10   659 ms   680 ms   896 ms  195.99.126.58
 11   636 ms   727 ms   529 ms  209.85.255.175
 12   458 ms   454 ms   489 ms  209.85.251.202
 13   931 ms  1016 ms   780 ms  74.125.230.146
Trace complete.
  1     1 ms     2 ms     3 ms  api.home [192.168.1.1]
  2  1074 ms   742 ms  1000 ms  esr1.miltonkeynes3.broadband.bt.net [217.47.74.140]
  3   834 ms   573 ms   446 ms  217.47.74.125
  4  1007 ms   904 ms   910 ms  213.1.69.106
  5  1044 ms   891 ms   848 ms  217.41.222.62
  6   995 ms   869 ms   844 ms  217.41.222.182
  7  1009 ms     *     1158 ms  acc2-10GigE-0-0-0-6.bm.21cn-ipp.bt.net [109.159.248.210]
  8  1048 ms     *     1345 ms  core2-te-0-2-5-0.ealing.ukcore.bt.net [109.159.248.130]
  9   848 ms   768 ms   755 ms  core4te-0-1-2-0.telehouse.ukcore.bt.net [109.159.254.46]
 10  1047 ms  1151 ms   607 ms  195.99.126.58
 11   850 ms   901 ms   854 ms  209.85.255.175
 12   734 ms   795 ms   822 ms  209.85.251.202
 13   929 ms   804 ms   632 ms  74.125.230.146
Trace complete.
There hasnt been a change to the way our homehub is set up or to any of the devices that we connect to it. The only change that I can think of is there are some roadworks going on and maybe this could have damaged the line maybe?
I have since been onto pingtest.net to test my connection there and this is where the problem is, because not only have I got quite a high latency of 1235ms(on that specific test) but I have also got a packet loss of 15% out of 250 packets which is really not good. There is also jitter on the line of 548ms.
I also tried the speedtester.bt.com but it has just timed out about 5 times now so clearly thats not going anywhere.
Has anyone got any advice, really dont want to ring a call centre in a place ive never heard of just to be asked "have you turned it off and then on again?"
Regards,
Alex
7 REPLIES 7
Message 2 of 8
Re: Incredibly High Latency and Low Download Speed
Finally was able to get the speedtester.bt.com to work after numerous trys and heres the result:
Test1 comprises of Best Effort Test: -provides background information.
Download  Speed
4200 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 4200 Kbps
 For your connection, the acceptable range of speeds is 600-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
 IP Profile for your line is - 6500 Kbps
Message 3 of 8
you are on adslmax and the btspeedtest figures look ok - speed 7616 with the correct profile of 6500 and download speed of 4200 probably due to people using net at peak time
Message 4 of 8
Yes I understand what youre saying but trying to use formula1.com for live timing and cannot use the internet. speedtest.net result shows 892ms latency and 0.03megabits per second download speed.
So to be honest really dont understand whats going on with the connection.
Message 5 of 8
you can check your exchange here for problems http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
still looks like congestion on your exchange - a lot of people using the internet at the peak time on your exchange
Message 6 of 8
Tried the links which you gave me and no problems came up. I understand what you mean about peak times and the connection lowering because of that but like this morning its becoming un-usable in peak times. Theres not much point if I can only achieve a decent connection at 3 in the morning.
What youre saying about the peak times would increase the latency and decrease download speed. But it wouldnt mean that theres a substantial loss of 20% packets being sent?
Do you have any information or know of somewhere where I can report a potential fault or issue with local exchanges?
Recognised Expert
Message 7 of 8
Hi Alex,
Is there any chance you could post your line stats so we can see if there are any errors on the line?
Here are some steps: http://www.kitz.co.uk/adsl/frogstats.php
___________________________________
Like this post? Give it a Star :D. If this post answers your question, please Mark it as the Accepted Solution.
Message 8 of 8
Hi, Sorry for the late reply.
Over the last week about half the time it has been fine, but especially in peak times it dies down to the point where it is unusable. Especially at night between around 9-12 its pathetic cant do anything on it, and then again around the 2-4.
I know people say well its peak time your connection will be slower, but it is just unsuable in those times stated above.
ADSL line status
Connection Information
Line stateConnected
Connection time8 days, 21:24:48
Downstream7,616 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)12.2 dB / 23.0 dB
Line attenuation (Down/Up)16.3 dB / 9.0 dB
Output power (Down/Up)
14.2 dBm / 1.6 dBm
