Message 21 of 51
Re: Incredibly Slow Broadband for 10 days
you can check here for any reported faults  08007830056
http://usertools.plus.net/exchanges/mso.php
http://usertools.plus.net/exchanges/?
http://btbusiness.custhelp.com/app/service_status
http://bt.custhelp.com/app/answers/detail/a_id/15036
with the connection problems you have and if you are in test socket, new filter and quiet line ok then I would get mods involved for help
contact mods
can take up to 3 working days for mods to contact you
Just an afterthought but have you tried another router?  if you don't have one can you borrow one jusy to eliminate the router
Vaughan
Message 22 of 51
Thanks again.
No reported problems at the exchange.
I have an old-ish D-Link router but can't get it too connect
Hopefully the Mods will be able to do something
Message 23 of 51
you need to change the user name and password on the d link username bthomehub@btroadband.com and a pass word of your choice
Vaughan
Message 24 of 51
Ok that worked. Now connected with the D-Link router. I'll leave it on and see how it copes this evening.
Stats from D - Link ......
Connection Type :PPPoE/PPPoA
Network Status :Connected
Connection Up Time :0:00:21:15
Downstream Line Rate :2528 kbps
Upstream Line Rate :448 kbps
Downstream
Upstream
Rate (Kbps):2528 kbps448 kbps
SNR Margin (dB):5.514.0
Attenuation (dB):63.531.5
Output Power (dBm):16.512.0
Super Frames:8324083240
RS Correctable Errors:554502
RS Uncorrectable Errors:90
HEC Errors:180
Total Cells:11333831378
Data Cells:11336631379
Bit Errors:00
Message 25 of 51
that is now looking ok stick with the dlink just please post us a full bt speedtest now please
Message 26 of 51
changing router has really helped and speed more like it should be - possibly faulty router before?
Vaughan
Message 27 of 51
 BT Speedtest results...........
Download speedachieved during the test was - 0.1 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
 Additional Information:
 Your DSL Connection Rate :2.53 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.14 Mbps
Message 28 of 51
yes your IP Profile is at rock bottom once you have 3+ days connection if your IP profile has not risen automatically then contact the mods for an IP profile reset
Message 29 of 51
I would doubt your profile is stuck but rock bottom due to your previous very low conenction speeds and it will recover automatically on it's own given a stable connection 24/7 for 3+days maybe sooner
Vaughan
Message 30 of 51
Remains to be seen what will happen when the speed drops down at its usual time in the late evening. I suspect it will be back to square one on connection time. Have contacted the mods anyway. I think it will have to be an engineering solution but who knows!
