Message 31 of 51
Re: Incredibly Slow Broadband for 10 days
The mods will need to see at least 3days stable connection before they can reset your profile also it should release automatically before then  the problem  looks like a faulty hub as your connection is  now at the speed it should be at
Message 32 of 51
I agree it certainly looks like a hub problem as stats now look ok with about normal 6db noise margin.  time will tell if it holds conenction tonight
Vaughan
Message 33 of 51
Would a faulty hub explain why I have experienced drop outs and/or extremely low speeds at pretty much the same time every evening?
Yesterday I was connected by home hub and the downstream speeds were also quite high until it all went pear shaped at 10pm. Dropped out, reconnected at the new low incoming speed (256kpbs)  but the connection clock had to start all over again. I think it also went down again at 3am, lost connection and reconnected at 160Kbps.  This is the seemingly unescapable loop I'm stuck in 😞
Also please note that at the low speed times the router was reporting very high noise margins which I thought was suggesting that the problem was with the line not the hub?
Message 34 of 51
need to wait now as stats look ok and see if connection drops again tonight or if router chnage has sorted it
Vaughan
Message 35 of 51
Sigh - 10:45pm connection lost on the D-Link. Won't reconnect so as an experiment I swap to home hub -  that does connect with these stats....
Back to square one it seems
Line stateConnected
Connection time0 days, 0:01:53
Downstream320 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.4 dB / 13.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)12.7 dBm / 11.9 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)6824 / 0
CRC Errors (Down/Up)177 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)12
Vaughan
Message 36 of 51
Is the downstrean output power a clue or is that just a function of downsream speed? The two do seem to be correlated
Message 37 of 51
downstream power looks fine
Vaughan
Message 38 of 51
Also looks like the noise margin is ok? but very low downstream speed?  Not seen that before
Message 39 of 51
hi without seeing a speedtest it is difficult to say about the download speed looking at your hub stats the down connection speed is correct
Vaughan
Message 40 of 51
Sppedtest results...
Download speedachieved during the test was - 0.11 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
 Additional Information:
 Your DSL Connection Rate :0.32 Mbp
