Message 41 of 51
Re: Incredibly Slow Broadband for 10 days
Hi just a matter of waiting for the modsto contact you know there is little you can do now
Message 42 of 51
Yes I guess so. Its incredibly frustrating niot knowing what the root cause is and whether BT are able to do anything or even taking this seriously
One thing I don't understand is why its affecting my house only and not those around me in or in the same street.
Just for the record it dropped out again this morning at 4:45am and went down to 160kbps before reconnecting.
Noise level is high now as below. I expect it will settle back down after 9am as it usually does 😕
Line stateConnected
Connection time0 days, 3:49:40
Downstream160 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)27.9 dB / 12.0 dB
Line attenuation (Down/Up)63.5 dB / 31.5 dB
Output power (Down/Up)11.1 dBm / 11.9 dBm
Download speedachieved during the test was - 0.12 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.25 Mbps.
 Additional Information:
 Your DSL Connection Rate :0.16 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.14 Mbp
Message 43 of 51
Hello
I have similar problems with some disconnections, usually late evenings or early mornings and when there are heavy rain storms. I have a long rural line with an ASDL 1 up to 8 meg exchange.
Leaving my router on 24/7 resulted in low IP proflie and downgrading of my Taget S.N.R from 9 to 12 db when I had a lot of disconnects last year. It still disconnects at these times with the higher TSNR so the higher margin is no of help, only reducing my connection speed.
I get the most stable and best connection during the day, from morning till mid evening. I have tried leaving on for 24/7 but find because of the noise event it will reconnect at a lower speed thus reducing my IP profile.
I have found the IP profile will increase in 3 days without  being on 24/7. I can turn my router off after about an hour  and not switch on again till the next day etc and providing It connects at the speed range for the higher Ip Profle, the profile will increase.
This is the way I use my broadband now as my line is too unsatable to leave on 24/7 and risk a further increase in the TSNR. So now I switch off my router when not in use and If I get caught by a bad disconnect I use the method above to get my profile back to speed.
Message 44 of 51
@Vaughan
getting worse just need to be patient until your email reaches the top of the mod inbox
Message 45 of 51
It will depend on your profile method of resetting - according to kitz and still seems to hold if you read the forum posts - 60% will recover profile in hours depending on percentage increase required, 40% still take 3/5 days connected 24/7 and finally the new profile system which is 88.2% of connection speed and changes immediately  this will help
check profile
Message 46 of 51
Someone from BT rang - they have been assigned to my case. The SNR? has been changed and they want to see what difference that makes over the next 24hrs and will then ring again.
Results from home hub show that noise level is down and that letency type has changed to fast - not sure what that means?
Anyway its just nice to know someone is actually doing something. He said if this did not work then an engineer would need to come out.
Line stateConnected
Connection time0 days, 0:07:45
Downstream2,176 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
Latency typeFast
Noise margin (Down/Up)6.3 dB / 14.0 dB
Output power (Down/Up)17.1 dBm / 11.9 dBm
Loss of Framing (Local)22
Loss of Signal (Local)2
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)5 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)16
Message 47 of 51
looks good just now with normal noise margin.  run btspeedtester and see if profile increased to match your increased speed.
just need to leave it and see it the connection stays stable
Message 48 of 51
mikew650 it may work for you but generally bad advise to keep restarting the hub as the best stability is found with a continuous connection also it sounds like your noise margin is to high due to the disconnections therefore reducing your possible connection speed if you would like more help then please start your own post and we can help you with your connection
Message 49 of 51
just keep us posted
Message 50 of 51
Will do. Thanks Chaps
You have been incredibly helpful and its very much appreciated.
