Zacg99
Message 1 of 25
Incredibly poor upload speed
Hey, I've noticed recently that I believe the package I'm on (max 8 mb/s, please correct if wrong) allows me to go up to 448 kb/s, but this is not the case. My download speed is 5 mb/s which is pretty good for my area (Aldbury, HP23 5RZ). But my upload speed . . . Most people get around 600 kb/s but me, I'm stuck on 228 kb/s which divided by 8 to get kilobytes/s . . . I don't want to say. Since I'm constantly uploading videos to youtube I just wanted to know is there ANY way to get better upload speed, since my download is good for my area.
PortStatusTxPktsRxPktsCollisionsTx B/sRx B/sUp Time
WANpppoa382511653053830331421792 days 01:52:08
LAN110M/100M40418202844122017695306914 days 04:50:32
LAN2Link Down--
LAN3Link Down--
LAN4Link Down--
WLAN300M10646473747648202293948172 days 01:52:25
ADSL LinkDownstreamUpstream
Connection Speed5824 kbps448 kbps
Line Attenuation29.0 db16.0 db
Noise Margin6.4 db23.0 db
Those upload/download speeds on there are a bit off from what I'm really getting. Download is 5 mb/s upload 228 kb/s. Is there any way to improve if it. Even if it means paying more?
24 REPLIES 24
drake178
Message 2 of 25
Re: Incredibly poor upload speed
Your up noise margin is strangely high compared to other stats I've seen, but I'm just a newbie, the CLs will likely have some proper ideas. You might also want to check out and post your results from the BT speedtester
Zacg99
Message 3 of 25
Speed tester won't load :L and when it does java plugin crashes. That's quality internet there
drake178
Message 4 of 25
What about the Flash one (wholesale)? You have to do the 'Further Diagnostics' there after the base test, from what I could tell that gave the same information.
Zacg99
Message 5 of 25
Further diagnostics = 'This test currently cannot be performed for your line, please try again later, or if this problem persists, contact bt' or something :L
drake178
Message 6 of 25
Does the basic one run there? If it does, what speeds do you get with it?
Zacg99
Message 7 of 25
4. 97 mb/s down
0.30 mb/s up 🙂
Zacg99
Message 8 of 25
Should I remove the bell wire in all phone sockets in my house, I heard thats what you do to lower noise on the line.
drake178
Message 9 of 25
Ouch. I wonder if ther's another way to check out your ip profile. You've had some problems recently if I remember right, did the downstream speed increase gradually or suddenly? It might be that it'll still be a few days before your line settles properly.
drake178
Message 10 of 25
You can always try that, I'm no expert on that though, there's none in the house 😄
