JacquiT
Community Manager - Retired
Message 11 of 26
Re: Induction Loop
Hi Rosiposie28
I have been and asked for some info around this for you and have been told that there are various ways to connect, it depends on the set top box you have and the loop unit.
Regarding the leads required, you need a phono lead, please see the image below, does this help any?
Jacqui
Phono to loop lead image
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted Solution’.
Rosieposie28
Message 12 of 26
Re: Induction Loop
Thank you. Do you know where I can buy these?
Steve_M
BT TV Expert
Message 13 of 26
Re: Induction Loop
Hi Rosie,
Do you know which one you need? I can get one sent out for you.
Steve
Rosieposie28
Message 14 of 26
Re: Induction Loop
There are only 2 small round openings in the back of my system - one black one red.  I do have the latest BT box as it was only fitted last Wednesday.
Steve_M
BT TV Expert
Message 15 of 26
Re: Induction Loop
Perfect, I will get one sent out tomorrow.
Steve
Rosieposie28
Message 16 of 26
Re: Induction Loop
Thank you, that's wonderful Smiley Happy
Rosieposie28
Message 17 of 26
Re: Induction Loop
Can I ask do the wires go straight from induction loop to theYouview Box? Do they not need to go into TV?
Steve_M
BT TV Expert
Message 18 of 26
Re: Induction Loop
I posted the lead yesterday so should be with you today/tomorrow.
I would suggest connecting:
  • youview HDMI -> TV HDMI (using HDMI cable)
  • youview Red/Black RCA -> Induction Loop system Red/Black RCA (using cable in post)
Steve
Rosieposie28
Message 19 of 26
Re: Induction Loop
Hi, the lead has arrived and it works. However the sound is very different from before. It has a kind of echo with it. Is this right? Is it something I will have to try and get used to?
Sue
Rosieposie28
Message 20 of 26
Re: Induction Loop
Hi again,  I have trawled through all the options on both TV and Youview.  I have altered one of the sound settings to get my loop sound back to normal. However this disables the sound to TV so that anyone wanting to watch with me has no sound. But it works for me. If there is any other way please let me know
Sue
