Hi all,
I had Infinity II installed about three weeks ago and when the technician was here it tested on BT's speed checker at 55Mb/s down, 17Mb/s up. After getting about 1.8Mb/s connection between home and BT before Infinity II, this was stunning! However, within a couple of days my download speed had dropped off to about 1Mb/s, so slower than it was before, and the upload speed was mirroring that quite closely. I did the troubleshooting and rebooted the shiny new homehub5 (homehub 4 before Infinity) and speeds increased again to about 48Mb/s down, 16Mb/s up. Within hours it had dropped back again to pitiful levels and if I leave it for 24 hours then it's pretty much unusable.
Just now ...
after I rebooted the hub about seven hours ago.
The connection speed between hub and BT has been dropping steadily. I'm guessing that because I have to reboot the homehub to get decent speeds for a while, the BT kit is assuming my line's unstable and is dropping the speed accordingly. Right now the hub's reporting 48Mb/s connection to BT, it was closer to 57Mb/s when it was installed.
Any suggestions?
Cheers,
Bill
Below. Thanks.
1. Product Name: HomeHub5
2. Serial number: +076284+1402016787
3. Firmware version: v0.07.01.0235-BT (Type B) Last updated [Unknown]
4. Board version: 01
5. VDSL uptime: 0 days, 01:00:16
6. Data Rate: 16560 / 49517
7. Maximum Data Rate: 14153 / 49513
8. Noise Margin: 4.4 / 5.6
9. Line Attenuation: 0.0 / 19.2
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 18.9 MB / 62.5 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
Only wifi. I've no devices with an Ethernet port.
Bill.
That's what I posted. Look at the speedtest graphic in the original post. I can reboot the router and run it again to show 46Mb/s down, 15Mb/s up.
Cheers,
Bill
Try turning off smart wireless then split the 2.4 and 5ghz networks giving each there selected channel number checking with a wifi analyser the best free channels. You can use same password. You can then log into both networks assuming your devices are caoable of the 5ghz network
many devices have a probkem with the 2 networks combined
2.4/5 already split, named differently, different passwords, no smart wifi, and I've worked my way through every channel over the last five days.
Bill
So these stats
are when you're seeing 1 or 2 Mbps on the speed test?
