Samphy
Message 1 of 5
Infinity 1 Installation questions
Hi all,
I desperately want fibre (and am looking at the Infinity 1 38meg package) but have hit the cancel button 3 times when ordering as I'm concerned about the following issues. Can any of you answer these questions from experience please?
1 - I have a wired set up currently, all my PCs/Macs and printers are plugged into a Netgear router which also has a WAP attached for my tablet/mobile devices. Will having the hub mean that I lose the ability to use all my wired devices across the network/on the internet?
2 - I don't want any BT software on any of my machines. Can I refuse to install it? Or is it necessary?
3 - Is it possible to self-install or do the engineers insist on having access to your PCs?
Any feedback gratefully received, cheers!
4 REPLIES 4
gg30340
Message 2 of 5
Re: Infinity 1 Installation questions
@Samphy wrote:
Hi all,
1 - I have a wired set up currently, all my PCs/Macs and printers are plugged into a Netgear router which also has a WAP attached for my tablet/mobile devices. Will having the hub mean that I lose the ability to use all my wired devices across the network/on the internet? Why would you think that. The BT Homehub is a router just the same as any other router and you can connect to its four LAN ports and or by wireless. It just so happens to have a VDSL integrated modem as well.
2 - I don't want any BT software on any of my machines. Can I refuse to install it? Or is it necessary? You do not need to install any BT software.
3 - Is it possible to self-install or do the engineers insist on having access to your PCs? Virtually all Infinity install are now self install unless BT deem it to be a "problem" install that requires an engineer install. In any event and engineer does not need to access your PC.
Samphy
Message 3 of 5
Thank you for replying so quickly.
1 - I have a wired set up currently, all my PCs/Macs and printers are plugged into a Netgear router which also has a WAP attached for my tablet/mobile devices. Will having the hub mean that I lose the ability to use all my wired devices across the network/on the internet? Why would you think that...
Browsing through a lot of the help pages, many of them suggest that wireless is the only option and as I couldn't find any mentions re wired I added 2+2 together and got 5 🙂 (http://bt.custhelp.com/app/answers/detail/a_id/9692#pc)
So, as a follow up, this would mean then that my Netgear and WAP box would be defunct as the Hub would do everything?
Thanks again!
gg30340
Message 4 of 5
Have a look at the specs of the HH5
http://www.shop.bt.com/products/bt-home-hub-5-068343-90RY.html
Yes your Netgear and WAP would be redundant.
john46
Message 5 of 5
