Message 1 of 7
Infinity 1 Speed
Got Bt Infinity installed yesterdat here are my stats
1. Best Effort Test: -provides background information.
 Download Speed
 37.36 Mbps
0 Mbps38.72 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 37.36 Mbps
 For your connection, the acceptable range of speedsis 12 Mbps-38.72 Mbps .
 Additional Information:
 IP Profile for your line is - 38.72 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 8.63 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 8.63Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
How come i am losing upload speed any ideas
6 REPLIES 6
Distinguished Expert
Message 2 of 7
Re: Infinity 1 Speed
The modem reserves 1Mb of upload for QOS.
To say thanks for a helpful answer, please click the white star
Message 3 of 7
So stats are good then
Message 4 of 7
Yes, you would probably get higher speeds on Infinity 2
Recognised Expert
Message 5 of 7
Yes your stats are fine,because you are getting a download reading of approx 37Mbps from a 38Mbps line profile,and also the same with the upload as on upload testing you are getting a reading of 8Mbps approx from a 10Mpbs profile.:)
Guru
Message 6 of 7
Additionally you would also lose some speeds(although not much), as you are using your connection to test it.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 7 of 7
Thanks for the replies all good at the mo
