Message 1 of 152
Infinity 1 and slow speeds during the evening and weekends
Was installed Tues 4th June.
Predicted speed was 21.5 down and 5.0up, when installed it was actually 28.0 so pleased with that.
I.P profile 25.
Speed is absolutely fine during the day - 24 down, but every evening it plummets to between 1-3 mb. This can be anytime from 7.00pm - midnight and can last 30 minutes or sometimes 4hrs.
I've ran hundreds of speed tests and from several sites. They all show the same results on both laptops wired and wireless.
I had a call from the network fault specialist team on Wed and was told they needed proof (I have already sent numerous attachments via online chat) so the next time it happens to report it again.
So tonight I contacted online chat again (cos my fault is due to be closed tomorrow) he then transferred my call to the escalation department. He ran loads of checks and diagnostics but couldn't find any fault. He said the only thing they could do was to get an engineer out, but he agreed with me that the engineer wouldn't see the fault either as it only happens during the evening.
I eventually agreed to the engineer visit being as there is nothing else I could do, but then he couldn't book one. It said on his system that being as the diagnostic tests didnt show a fault no engineer is required.
He said my only option now is to pay for a local technician, which I refuse to do or to ring 0800 800 150 option 2 the cancellation department.
Runs perfectly during the day but terrible in the evening, what else can I do?
home hub 3 and ecl modem have both been reset, makes no difference, other than slightly lowering my i.p profile!
151 REPLIES 151
Message 2 of 152
Re: Infinity 1 and slow speeds during the evening
22nd June 2013 23:43:575488 Kbps19600 Kbps
22nd June 2013 23:23:135466 Kbps1571 Kbps
22nd June 2013 23:17:225251 Kbps1947 Kbps
22nd June 2013 23:13:585378 Kbps2858 Kbps
22nd June 2013 23:09:205429 Kbps4034 Kbps
22nd June 2013 23:03:175431 Kbps12034 Kbps
22nd June 2013 22:37:505521 Kbps2532 Kbps
22nd June 2013 22:37:065318 Kbps2763 Kbps
22nd June 2013 22:23:215289 Kbps1543 Kbps
22nd June 2013 22:20:365327 Kbps1652 Kbps
22nd June 2013 21:49:095456 Kbps1459 Kbps
22nd June 2013 21:38:215478 Kbps2158 Kbps
22nd June 2013 21:37:015448 Kbps1534 Kbps
22nd June 2013 21:35:565503 Kbps1466 Kbps
22nd June 2013 21:34:425499 Kbps1689 Kbps
22nd June 2013 21:32:585459 Kbps1737 Kbps
22nd June 2013 21:31:155489 Kbps2266 Kbps
22nd June 2013 21:28:045529 Kbps2614 Kbps
22nd June 2013 21:25:385487 Kbps2039 Kbps
22nd June 2013 21:25:025524 Kbps4982 Kbps
22nd June 2013 21:22:355448 Kbps1971 Kbps
22nd June 2013 21:12:505476 Kbps2580 Kbps
22nd June 2013 21:06:255455 Kbps2497 Kbps
22nd June 2013 20:57:485496 Kbps2527 Kbps
22nd June 2013 20:51:505420 Kbps1699 Kbps
22nd June 2013 20:50:475136 Kbps1741 Kbps
22nd June 2013 20:49:595399 Kbps2257 Kbps
22nd June 2013 20:49:275432 Kbps3208 Kbps
22nd June 2013 20:43:145346 Kbps2375 Kbps
22nd June 2013 20:34:495417 Kbps20750 Kbps
22nd June 2013 20:32:145411 Kbps21722 Kbps
Distinguished Expert
Message 3 of 152
Can you post a tracert to bbc.co.uk please?
To say thanks for a helpful answer, please click the white star
Message 4 of 152
Do I need to do that whilst it's slow in the evening cos it's ok at the moment?
Expert
Message 5 of 152
You need to post when it is slow as well so we can compare the tracert's and see where it is picking up the delay. It would also be useful if you could tell us roughly where you are in the country as well.
My intial thoughts are that it is a throughput issue that you are getting in the evenings - we used to get it when we were on standard ADSL but never see it now we are on Infinity. The reason you shouldn't see it is that if they have sized the "back-haul" correctly between the FTTC cabinet and the BRAS then the link between the BRAS and the 21CN network - where you actually hit the UK Internet backbone for BT - is sized correctly. The only thing that I could see would have an impact is whether the FTTC cabinet that you are connected too is overloaded.
Infinidim
Megadodo Publications
Ursa Minor Beta
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side
If the the reply answers your question then please mark as ’Mark as Accepted Solution’
Message 6 of 152
Ok thanks.
This is now whilst i'm getting 20mb and I'll post one when it's slow tonight.
I'm on the Chester North exchange.
Message 7 of 152
My speed has started to nose dive early today.
This was from a few minutes ago when it dropped to 5mb
Expert
Message 8 of 152
tango2 - it is looking like a "back-haul" issue and loading related from what you have posted above. BT Wholesale should be able to fix this.
The 109.159.2....before the "ealing.ukcore" address is a 21CN node but you can't see the reverse DNS for it. Most of the addresses in the tracert are private BT GRoup ones which you will not get reverse DNS names for. If there weren't issues then I would expect RTD to "ealing.ukcore" to be about 26/28 ms. The next hop from "ealing.ukcore" to "telehouse" I would expect to add much as it is in the Docklands (London). If there is a lot going on at the BBC then the 194.74.65.42 and the "Cable and Wireless - now Vodafone" access to the BBC does gain quite a lot of delay.
Hope this helps
Infinidim
Ursa Minor Beta
Message 9 of 152
Thanks infinidim, so what do I need to do to get it resolved?
Expert
Message 10 of 152
If you have tried the normal path 08001114567 and fought the help desk in India and not got anywhere then I would contact the moderators for this forum. They are quite busy and tend to take 3 or 4 days to get back to you but they do seem to get things fixed. They are basically "problem managers" with access to all parts of BT.
Infinidim
Ursa Minor Beta
