arbeeuk
Message 1 of 34
Infinity 1 download speed slower than before upgrade
I upgraded to infinity 1 last week and found that d/load speeds are no better than before.
My d/load speed before infinity was around 8+mb
here are test checks
Exchange DENTON is served by Cabinet 7
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High
Low
High
Low
FTTC Range A (Clean)
80
78.1
20
20
Available
FTTC Range B (Impacted)
80
67.2
20
19
Available
WBC ADSL 2+
Up to 17
10 to 19.5
Available
WBC ADSL 2+ Annex M
Up to 17
Up to 1.5
10 to 19.5
Available
ADSL Max
Up to 7.5
6.5 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
FTTP on Demand
330
30
Available
Fibre Multicast
Available
FAQ
1. Best Effort Test: -provides background information.
Download Speed
7.71 Mbps
0 Mbps
7.18 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 7.71 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-7.18 Mbps .
 Additional Information:
 IP Profile for your line is - 7.18 Mbps
2. Upstream Test: -provides background information.
Upload Speed
1.41 Mbps
0 Mbps
2 Mbps
Upload speed achieved during the test was - 1.41Mbps
 Upstream Rate IP profile on your line is - 2 Mbps
33 REPLIES 33
gg30340
Message 2 of 34
Re: Infinity 1 download speed slower than before upgrade
Doesn't look like you are on Infinity 1 to me. Your Up IP profile should be showm as 10Mbps not 2Mbps.
Use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down.
http://speedtest.btwholesale.com/
arbeeuk
Message 3 of 34
Thanks for the prompt reply
I thought that info was what I posted. anyway ran it again and here is diagnostic result....
Results Image not loaded
 Download Speed
 7.38 Mbps
0 Mbps7.18 Mbps
 Download speedachieved during the test was - 7.38 Mbps
 Upload Speed
 1.41 Mbps
0 Mbps2 Mbps
The test result has indicated that you should contact your ISP for further assistance.
legitimise_sailing
Distinguished Expert
Message 4 of 34
Are you still using the Homehub that you had before the upgrade?
To say thanks for a helpful answer, please click the white star
arbeeuk
Message 5 of 34
No it was HH4 but now using HH5.
legitimise_sailing
Message 6 of 34
What line stats does it report in Troubleshooting, Helpdesk?
gg30340
Message 7 of 34
It certainly appears to me that you are on ADSL and not Infinity. Was it a self install or did an engineer connect it up for you. When was your go live date?
arbeeuk
Message 8 of 34
Is this what you mean?
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ35026407
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated 04/02/14
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 05:19:08
6. Data rate:1999 / 7415
7. Maximum data rate:8168 / 9574
8. Noise margin:13.8 / 7.1
9. Line attenuation:0.0 / 42.9
10. Signal attenuation:0.0 / 40.9
11. Data sent/received:25.4 MB / 3.1 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-57H3
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 150 Mb/s)) 20 MHz, WPS enabled
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 2.4 GHz Wireless network/SSID:BTWiFi-with-FON
19. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 150 Mb/s)) 20 MHz, WPS disabled
20. 2.4 GHz Wireless security:None
21. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
22. 2.4 GHz Wireless network/SSID:
23. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 150 Mb/s)) 20 MHz, WPS disabled
24. 2.4 GHz Wireless security:None
25. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
26. 2.4 GHz Wireless network/SSID:Auto-BTWiFi
27. 2.4 GHz Wireless connections:Disabled
28. 2.4 GHz Wireless security:None
29. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
30. 2.4 GHz Wireless network/SSID:
31. 2.4 GHz Wireless connections:Disabled
32. 2.4 GHz Wireless security:None
33. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
34. 5 GHz Wireless network/SSID:BTHub5-57H3
35. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s)) 80 MHz, WPS enabled
36. 5 GHz Wireless security:WPA2
37. 5 GHz Wireless channel:Automatic (Smart Wireless)
38. 5 GHz Wireless network/SSID:BTWiFi-with-FON
39. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s)) 80 MHz, WPS disabled
40. 5 GHz Wireless security:None
41. 5 GHz Wireless channel:Automatic (Smart Wireless)
42. 5 GHz Wireless network/SSID:
43. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s)) 80 MHz, WPS disabled
44. 5 GHz Wireless security:None
45. 5 GHz Wireless channel:Automatic (Smart Wireless)
46. 5 GHz Wireless network/SSID:Auto-BTWiFi
47. 5 GHz Wireless connections:Disabled
48. 5 GHz Wireless security:None
49. 5 GHz Wireless channel:Automatic (Smart Wireless)
50. 5 GHz Wireless network/SSID:
51. 5 GHz Wireless connections:Disabled
52. 5 GHz Wireless security:None
53. 5 GHz Wireless channel:Automatic (Smart Wireless)
54. Firewall:Default
55. MAC Address:34:8a:ae:70:6e:a6
56. Software variant:-
57. Boot loader:-
arbeeuk
Message 9 of 34
It was a self install and the date was 5/2/14
legitimise_sailing
Message 10 of 34
Ouch.
Yeah, that's the stats.
Ok, good news is you're on Infinity.
Bad news is you have extremely high attenuation which bears no relation to the estimate from the DSL checker.
Did you have a problem install?
