legitimise_sailing
Distinguished Expert
Message 11 of 34
Re: Infinity 1 download speed slower than before upgrade
Oh, a self install. You really need an engineer...
To say thanks for a helpful answer, please click the white star
arbeeuk
Message 12 of 34
No the install seemed to be ok. I started the HH5 and it connected about 2 hours after the cab man did his thing.
legitimise_sailing
Message 13 of 34
I suspect a wiring problem but I'm unsure whether it's your internal wiring or external before the wire enters your property.
gg30340
Message 14 of 34
You are going to have to contact BT and report a fault to them. Inform them that you did a self install and the poor speeds you have. They should send an engineer out to check things out.
legitimise_sailing
Message 15 of 34
I guess they'll charge 130 quid if it's internal
arbeeuk
Message 16 of 34
ok. Thanks for the help and replies .
do you know the bt fault reporting number? save me some time searching.
gg30340
Message 17 of 34
Broadband faults  0800 111 4567
Seamie
Message 18 of 34
Post some pictures of your setup and maybe someone might spot a potential problem
gg30340
Message 19 of 34
There should not be a charge. It should be classed as part of your install. If an engineer had called in the first place he would have sorted any faults, internally or externally as part of the install.
arbeeuk
Message 20 of 34
There is no internal wiring. The dropwire goes straight into a box at the front window and I plugged straight in to it. There are no extensions. The cab is about 20 yards away.
