gg30340
Message 21 of 34
Re: Infinity 1 download speed slower than before upgrade
Have you a filtered master socket or did you use the micro filters supplied with the Homehub 5?
Keith_Beddoe
Message 22 of 34
Can you connect it like this example? Ignore the fact that the diagram says ADSL, its the same for Infinity self install.
arbeeuk
Message 23 of 34
I used the supplied micro filters. I dont have a test socket.
Keith_Beddoe
Message 24 of 34
So you only needed one filter, and plugged it into your master socket, then plugged the home hub and the phone into that single microfilter?
Like this, with the home hub in the small socket, and the phone in the larger one?
There must be nothing else connected before the microfilter, even a phone splitter, or that will cause problems.
ADSL microfilter
legitimise_sailing
Distinguished Expert
Message 25 of 34
A photo of the dropwire would help
To say thanks for a helpful answer, please click the white star
arbeeuk
Message 26 of 34
Yep thats the socket I have and thats how I set it up.
Could I just say, it may help. The upload speed has gone up from about 400kb to 1.7 mb.
Keith_Beddoe
Message 27 of 34
Then I guess that the fault is elsewhere. Have you left it connected, powered up, and undisturbed fot 10 days, as specified, to allow the speed to stabilise?
If you did, then there must be an external problem.
arbeeuk
Message 28 of 34
It was only set up last wed(5th feb). But I have been told that there is no stabilisation period for infinity.
gg30340
Message 29 of 34
There is a ten day training period but that is not your problem. You should have been getting near your estimated speeds from the start.
arbeeuk
Message 30 of 34
Thanks again. I will contact the 0800 no monday morning  and see what happens from there.
