Message 1 of 24
Infinity 1 erractic ping & really slow upload
Hi,
@DavidMand @JohnC2, i posted a while ago about erractic connection that was very slow, link below -
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Infinity-1-Extremely-Slow-Please-Help/td-p/...
My connection has been really good up until yesterday where it is doing it again, very slow upload speed and erractic ping.
I've pasted the same info required below :-
1. Product name:BT Home Hub
2. Serial number:+068543+NQ60341657
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 30/11/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:06:30
6. Data rate:1637 / 38274
7. Maximum data rate:1633 / 41595
8. Noise margin:5.3 / 5.7
9. Line attenuation:23.9 / 24.4
10. Signal attenuation:24.3 / 22.0
11. Data sent/received:1.9 MB / 27.9 MB
12. Broadband username:
bthomehub@btbroadband.com
Telephone Number XXXXXXXX on Exchange CHELTENHAM is served by Cabinet 79
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
  HighLowHighLow
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean)40.130.87.75.427.4Available----Yes--
VDSL Range B (Impacted)34.518.27.33.915Available----Yes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 4.5--3 to 7Available--------
ADSL MaxUp to 3--2 to 4Available--------
WBC Fixed Rate1 ----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
The upload used to sync at around 7 but now is much less.
Could you have a look into it for me?
Thanks,
Chris
23 REPLIES 23
Message 2 of 24
Re: Infinity 1 erractic ping & really slow upload
bump
Message 3 of 24
Please can someone look into this! BT phone support are no help and this has been going on for days! I am unable to use remote desktop functions for work as my upload is now far too slow!
Moderator
Moderator
Message 4 of 24
Hi @acredo sorry that you are experiencing problems again with your connection.
Please can you complete a speed test and post the results.
John
Message 5 of 24
Thanks @JohnC2
From BT Wholesale Site
Download - 36.65
Upload - 1.15
Moderator
Moderator
Message 6 of 24
Hi @acredo Thanks for checking that for me.
The upload is very slow. Drop us over send us your details and we be happy to check this further for you. You can contact us by clicking on my user name and selecting contact the mods.
John
Message 7 of 24
Thanks @JohnC2 submitted the form.
Moderator
Moderator
Message 8 of 24
Hi @acredo Thanks for taking my call earlier.
As requested can you please conduct a speed test when directly connected to the test socket with no other devices connected and post the results.
You can check What type of master socket do I have to help you locate the test socket.
cheers
John
Message 9 of 24
Hi @JohnC2 thanks for looking into this.
Please see results below using test socket with new splitter and dsl cable plugged directly in by ethernet to the router
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 26/10/17
5. DSL uptime:0 days, 00:02:28
6. Data rate:1143 / 39950
7. Maximum data rate:1143 / 40019
8. Noise margin:6.1 / 6.1
9. Line attenuation:23.1 / 23.9
10. Signal attenuation:23.3 / 21.5
11. Data sent/received:0.5 MB / 4.0 MB
BT Wholesale Test
Down - 35.91
Up - 0.72
Ping - 45.13
The socket is a Master Socket (dual dsl + phone) MK3
Thanks,
Chris
Moderator
Moderator
Message 10 of 24
Hi @acredo Thanks for checking that and posting the stats.
Have you just noticed that the upload is slow or does it just freeze completely when you are uploading?
cheers
John
