Quaid
Message 1 of 106
Infinity 1 was 39Mbit, now 2 evening/weekends
Hi folks, been having some issues with slow broadband. When it was first "installed" in late August they didn't actually make the connection in the cabinet, so eventually got an engineer out on 7th september, he checked all the internal wiring and said it's OK, went and checked the cabinet and got it working, was getting essentially the advertised speed- 39Mbit down and 9.9 up -type speeds. This was at 10am on a monday morning.
As of about 2 weeks ago it is a lot slower. Done some speed tests and its about 1-3 in the evening and weekends, 7-20 overnight. I live in south manchester so I have a sneaking suspicion it's related to the large numbers of students who have moved in about 2 weeks ago.
Not quite sure what the best course of action is, I really don't want to have to take another day off work as I had 3 when it was first installed.
Here are stats when it's plugged in the NTE5 test socked
Some stats when on wireless on the other phone socket
105 REPLIES 105
pippincp
Message 2 of 106
Re: Infinity 1 was 39Mbit, now 2 evening/weekends
Looking at your stats etc does seem to comfirm congestion at the exchange.
Quaid
Message 3 of 106
OK, is there anything I can do about it? I wouldn't mind if it was 38 dropping to 20 but dropping to <2 is ridiculous
BarneyG
Message 4 of 106
Hi Quaid,
Although we're seemingly opposite ends of the country, I'm seeing very similar issues with my Infinity 1 - see my thread here.
Off-peak I see cracking performance (38Mbps or thererabouts) but, like you, from 1600 until 2400 download speeds drop off a cliff - down to around 1 or 2Mbps.
Does anybody know if there's anything that can be done and if so, who we'd need to contact in order to escalate the issue?
Best regards,
Barney.
Chico1996
Message 5 of 106
This is very similar to what i'm experiencing too! If you have steam by any chance are your downloads just as slow or are they in line with your off-peak speeds?
syafiq
Message 6 of 106
I am from south Manchester and getting getting 1.6Mb
 Download speedachieved during the test was - 1.61 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-38.72 Mbps .
 Additional Information:
 IP Profile for your line is - 38.72 Mbps
Upload speed achieved during the test was - 7.8Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
john46
Message 7 of 106
are you using a wired connection when doing the speed test
syafiq
Message 8 of 106
BT Infinity 1 <2Mb at Manchester
Dear BT team,
I hope you could be of assistance.  I subscribed to Unlimited Broadband with BT Infinity 1
Speed test from http://diagnostics.bt.com/ shows ;
Download speed 1.65Mb
Upload speed 6.63Mb
# Please note - Tested with ethernet connectrion and no ohter device is connected to router
exchange details (https://www.btwholesale.com/includes/adsl/main.html)
Telephone Number xxxxxx on Exchange RUSHOLME is served by Cabinet 77
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
  HighLowHighLow
FTTC Range A (Clean)80682020--Available
FTTC Range B (Impacted)8061.32019--Available
WBC ADSL 2+Up to 10.5--7.5 to 13Available
WBC ADSL 2+ Annex MUp to 10.5Up to 1.57.5 to 13Available
ADSL MaxUp to 7--6 to 8Available
WBC Fixed Rate2 ----Available
Other Offerings
FTTP on Demand33030--Available
Fibre Multicast------Available
Copper Multicast------Available
Results  from http://speedtest.btwholesale.com/ ;
# NOTE - Using the test hub same speed
The problem is perseting for two weeks now, I have used the chat to contact BT & even call.... problem still not resolved
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51959216
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 04/09/15
4. Board version:BT Hub 5A
5. DSL uptime:2 days, 15:34:15
6. Data rate:10000 / 40000
7. Maximum data rate:24792 / 76276
8. Noise margin:14.4 / 16.3
9. Line attenuation:12.8 / 12.3
10. Signal attenuation:12.9 / 12.4
11. Data sent/received:2.1 GB / 6.3 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
Speed of 1.6Mb is unacceptable.
imjolly
Message 9 of 106
Re: BT Infinity 1 <2Mb at Manchester
Please delete the vol ref for your security
you are second person posting on Rusholme exchange have very low download speed
i have asked mods to help
Quaid
Message 10 of 106
Cheers imjolly you are a hero. Syafiq you are not alone we'll fight this together!
