esc4p3
Message 1 of 2
Infinity 1 - what changes your broadband speeds?
hi again
I have a couple of questions. When I first posted on this forum, I had posted the stats below
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 01/06/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 23:29:48
6. Data rate:2615 / 20947
7. Maximum data rate:2615 / 21055
8. Noise margin:6.2 / 6.2
9. Line attenuation:36.3 / 28.5
10. Signal attenuation:36.0 / 23.7
11. Data sent/received:352.1 MB / 5.1 GB
The above was from the 17th June.
Checking again today it says
5. DSL uptime:0 days, 03:17:17
6. Data rate:2771 / 19965
7. Maximum data rate:2758 / 19929
8. Noise margin:5.8 / 6.0
9. Line attenuation:36.0 / 28.3
10. Signal attenuation:35.9 / 23.6
11. Data sent/received:116.3 MB / 552.2 MB
12. Broadband username:bthomehub@btbroadband.com
In the intervening period, my maximum data rate dropped as low as 18mb or so. But following a spontaneous router reboot earlier - no idea why it rebooted it wasn't me - the upload is showing faster than it ever has whilst the download has recovered a bit. Is this just to be expected as I have only been connected for 3 weeks or so.
Also, presumably the data in line 11 resets after a router reboot?
thanks in advance 🙂
1 REPLY 1
imjolly
Message 2 of 2
Re: Infinity 1 - what changes your broadband speeds?
your estimate was 23/16mb and you are still within estimate  a 1mb drop i speed after a reset is not unusual and it may increase by the same amout when hub next resets
