Scoot
Message 1 of 10
Infinity 2 27Mb
I have BT Infinity 2 and was promised up to 76 Mb. Well I was getting up to 50Mb then I went for BT UHD TV which should have been fine. It uses about 30 Mb but should leave 20 Mb plenty. Unfortunately now my speed is maxing out at 27 Mb. So I thought it was my BT UHD TV but I've switched it off, disconnected it, run the the BT Hub 5 on its own and still 27 Mb. I went onto BT Broadband Speed Test and it tests my house line and still only 27Mb. The BT engineer tested my line before installing BT TV and was happy that it could handle UHD, and was about 46/50Mb at the time.
So not only am I not getting the speed I pay for, I only can use UHD TV at the expensive of the rest of my house. I feel like Im getting riped off twice. Any advice on what is happening on my line and how I get BT to fix. Thanks
9 REPLIES 9
imjolly
Message 2 of 10
Re: Infinity 2 27Mb
go to hub manager then troubleshooting then helpdesk and post 1-12
enter your phone number and post results results. Remember o delete number. https://www.btwholesale.com/includes/adsl/main.html
pippincp
Message 3 of 10
Re: Infinity 2 27Mb
Log into the HH5 and copy and paste lines 1-12 from the troubleshooting/helpdesk page.
Scoot
Message 4 of 10
Re: Infinity 2 27Mb
Thanks I will post in the morning
Scoot
Message 5 of 10
Re: Infinity 2 27Mb
1. Product name: BT Home Hub
2. Serial number: +068343+NQ41301318
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 07/07/15
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 12:38:21
6. Data rate: 20000 / 35000
7. Maximum data rate: 20495 / 42409
8. Noise margin: 6.0 / 7.9
9. Line attenuation: 20.6 / 19.4
10. Signal attenuation: 20.5 / 19.3
11. Data sent/received: 267.6 MB / 3.0 GB
12. Broadband username: bthomehub@btbroadband.com
Scoot
Message 6 of 10
Re: Infinity 2 27Mb
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps) Availability Date High Low High Low FTTC Range A (Clean) 74 54.9 20 16.2 -- Available FTTC Range B (Impacted) 65.1 39.4 20 11.5 -- Available WBC ADSL 2+ Up to 3.5 -- 2 to 6 Available WBC ADSL 2+ Annex M Up to 3.5 Up to 0.5 2 to 6 Available ADSL Max Up to 2.5 -- 1.5 to 5 Available WBC Fixed Rate 1 -- -- Available Fixed Rate 1 -- -- Available Other Offerings Fibre Multicast -- -- -- Available Copper Multicast -- -- -- Available
imjolly
Message 7 of 10
Re: Infinity 2 27Mb
was this self install?  if so have you tried using the test socket with a new filter and see if that improves your conenction speed  test socket.jpg
Scoot
Message 8 of 10
Re: Infinity 2 27Mb
It's not a self install. A BT engineer fitted it. I was asked by BT help to follow the step you suggested and I got the same test results.
imjolly
Message 9 of 10
Re: Infinity 2 27Mb
Then you need to phone customer services and get engineer visit as your connection speed is lower than your estimated speed
was it an openreach engineer of was it a contractor who was probably in and out in 15 min. Did engineer check to see if speed was within estimate?
Scoot
Message 10 of 10
Re: Infinity 2 27Mb
Thank you. I have an engineer coming around on Tuesday.
Fyi - it was a BT TV engineer who installed my TV that moved my BT Hub and reconnected it etc. Seems to be too coincidental.
ill let you know how I get on
