Message 1 of 9
Infinity 2 Constant drop out Slow speeds
Hey BT people please help, for about 6 or 7 weeks now my connection has been cutting out and dropping between 4-8 times an hour and I've finally had enough.
When first purchased the Infinity 2 package I was getting over 50mbs which I was delighted with but now with the constant cutting out I believe I've been "bandes" from what I can tell from other people's posts on these forums.
I'm getting anything between 1 - 30mbs which for the money we're paying isn't acceptable.
Here are some things that's might help;
Time and date Message
11:05:58, 31 Aug. (50663.070000) Admin login successful by 192.168.1.65 on HTTP
11:05:27, 31 Aug. (50632.190000) New GUI session from IP 192.168.1.65
11:04:42, 31 Aug. (50587.350000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>3659, internal ports: 3659, internal client: 192.168.1.64
11:04:35, 31 Aug. (50580.680000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any-​>3659, internal ports: 3659, internal client: 192.168.1.64
11:01:39, 31 Aug. BLOCKED 1 more packets (because of ICMP replay)
11:01:37, 31 Aug. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 3 192.168.1.65-​>64.233.184.102 on ppp3)
11:00:50, 31 Aug. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.65]:48146-​>[31.13.90.37]:443 on ppp3)
10:47:19, 31 Aug. (49544.690000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>3659, internal ports: 3659, internal client: 192.168.1.64
10:47:16, 31 Aug. (49541.060000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any-​>3659, internal ports: 3659, internal client: 192.168.1.64
10:45:49, 31 Aug. (49454.530000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>3659, internal ports: 3659, internal client: 192.168.1.64
10:45:45, 31 Aug. (49450.350000) Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any-​>3659, internal ports: 3659, internal client: 192.168.1.64
10:44:45, 31 Aug. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:9308 <-​-​> [86.143.237.103]:9308 -​ -​ -​ [52.40.62.70]:3479 ppp3 NAPT)
10:44:44, 31 Aug. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:9308 <-​-​> [86.143.237.103]:9308 -​ -​ -​ [52.40.62.71]:3479 ppp3 NAPT)
10:43:44, 31 Aug. IN: ACCEPT [57] Connection closed (Port Forwarding: UDP [192.168.1.64]:9308 <-​-​> [86.143.237.103]:9308 -​ -​ -​ [86.143.237.103]:1024 local_dev NAPT)
10:43:33, 31 Aug. (49317.870000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>9308, internal ports: 9308, internal client: 192.168.1.64
10:43:30, 31 Aug. (49314.950000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>9308, internal ports: 9308, internal client: 192.168.1.64
10:43:29, 31 Aug. (49314.000000) Device disconnected: Hostname: udhcp-​1-​18-​1-​VD-​Linux-​VDLinux-​1-​2-​1-​x-​c4-​73-​1e-​bd-​a9-​f3 IP: 192.168.1.72 MAC: c4:73:1e:bd:a9:f3
10:43:29, 31 Aug. (49314.000000) Device disconnected: Hostname: Martins-​iPhone IP: 192.168.1.71 MAC: 38:ca:da:7c:b1:73
10:43:29, 31 Aug. (49314.000000) Device disconnected: Hostname: Jamess-​iPhone IP: 192.168.1.69 MAC: 54:9f:13:77:91:c5
10:43:29, 31 Aug. (49313.990000) Device disconnected: Hostname: Masons-​iPhone IP: 192.168.1.68 MAC: ac:3c:0b:d1:fe:cf
10:43:29, 31 Aug. (49313.990000) Device disconnected: Hostname: android-​41b064fbc7f7a7bd IP: 192.168.1.66 MAC: 38:1d:d9:7b:36:2f
10:43:27, 31 Aug. (49311.990000) Lease for IP 192.168.1.64 renewed by host PS4-​ec-​0e-​c4-​7f-​76-​8d (MAC ec:0e:c4:7f:76:8d). Lease duration: 1440 min
10:43:27, 31 Aug. (49311.990000) Device connected: Hostname: PS4-​ec-​0e-​c4-​7f-​76-​8d IP: 192.168.1.64 MAC: ec:0e:c4:7f:76:8d Lease time: 1440 min. Link rate: 72.6 Mbps
10:43:27, 31 Aug. (49311.900000) Lease requested
10:43:25, 31 Aug. ath00: STA ec:0e:c4:7f:76:8d IEEE 802.11: Client associated
10:43:24, 31 Aug. (49308.990000) Device disconnected: Hostname: udhcp-​1-​18-​1-​VD-​Linux-​VDLinux-​1-​2-​1-​x-​c4-​73-​1e-​bd-​a9-​f3 IP: 192.168.1.72 MAC: c4:73:1e:bd:a9:f3
10:43:24, 31 Aug. (49308.990000) Device disconnected: Hostname: Martins-​iPhone IP: 192.168.1.71 MAC: 38:ca:da:7c:b1:73
10:43:24, 31 Aug. (49308.990000) Device disconnected: Hostname: Jamess-​iPhone IP: 192.168.1.69 MAC: 54:9f:13:77:91:c5
10:43:24, 31 Aug. (49308.990000) Device disconnected: Hostname: Masons-​iPhone IP: 192.168.1.68 MAC: ac:3c:0b:d1:fe:cf
10:43:24, 31 Aug. (49308.990000) Device disconnected: Hostname: android-​41b064fbc7f7a7bd IP: 192.168.1.66 MAC: 38:1d:d9:7b:36:2f
10:43:24, 31 Aug. (49308.990000) Device disconnected: Hostname: PS4-​ec-​0e-​c4-​7f-​76-​8d IP: 192.168.1.64 MAC: ec:0e:c4:7f:76:8d
10:43:22, 31 Aug. ath00: STA ec:0e:c4:7f:76:8d IEEE 802.11: Client disassociated
10:43:04, 31 Aug. IN: BLOCK [5] Fragmented packet (IP 192.168.1.64-​>52.40.62.68 fragment_offset=1480)
10:43:03, 31 Aug. IN: BLOCK [5] Fragmented packet (UDP 192.168.1.64-​>52.40.62.68 fragment_offset=0)
10:42:44, 31 Aug. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:9308 <-​-​> [86.143.237.103]:9308 -​ -​ -​ [86.143.237.103]:1024 local_dev NAPT)
10:42:44, 31 Aug. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:9308 <-​-​> [86.143.237.103]:9308 -​ -​ -​ [52.40.62.71]:3479 ppp3 NAPT)
10:42:43, 31 Aug. IN: ACCEPT [54] Connection opened (Port Forwarding: UDP [192.168.1.64]:9308 <-​-​> [86.143.237.103]:9308 -​ -​ -​ [52.40.62.70]:3479 ppp3 NAPT)
10:42:42, 31 Aug. (49267.490000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>9308, internal ports: 9308, internal client: 192.168.1.64
10:42:31, 31 Aug. (49255.970000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>9308, internal ports: 9308, internal client: 192.168.1.64
10:42:24, 31 Aug. (49249.650000) Lease for IP 192.168.1.64 renewed by host PS4-​ec-​0e-​c4-​7f-​76-​8d (MAC ec:0e:c4:7f:76:8d). Lease duration: 1440 min
10:42:24, 31 Aug. (49249.650000) Device connected: Hostname: PS4-​ec-​0e-​c4-​7f-​76-​8d IP: 192.168.1.64 MAC: ec:0e:c4:7f:76:8d Lease time: 1440 min. Link rate: 55.0 Mbps
10:42:24, 31 Aug. (49249.560000) Lease requested
Connection Information
Connection time: 0 days, 12:15:46
Data Transmitted/Received: 450.6 MB / 6.6 GB
Broadband username: bthomehub@btbroadband.com
Password: Not configured
TCP/IP settings
Broadband network IP address: 86.143.237.103
Default gateway: 172.16.10.134
Primary DNS: 81.139.57.100
Secondary DNS: 81.139.56.100
DSL Line Status
Line state: Connected
Connection time: 0 days, 12:22:12
Downstream: 37.38 Mbps
Upstream: 13.4 Mbps
As you can see my downstream has been lowered. It was in the 50s when I first got it.
Do any ideas what the problem Is? Thanks.
8 REPLIES 8
Message 2 of 9
Re: Infinity 2 Constant drop out Slow speeds
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
Message 3 of 9
Thanks for the reply.
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 22.5 -- 20.5 to 24 Available -- --
WBC ADSL 2+ Annex M Up to 22.5 Up to 1.5 20.5 to 24 Available -- --
ADSL Max Up to 8 -- 7 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
ADSL Multicast -- -- -- Available -- --
Fo
1. Product name: BT Home Hub
2. Serial number: +068543+NQ61204497
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 26/05/16
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 03:55:20
6. Data rate: 13184 / 38274
7. Maximum data rate: 13273 / 54826
8. Noise margin: 6.8 / 11.2
9. Line attenuation: 31.6 / 20.6
10. Signal attenuation: 31.6 / 20.4
11. Data sent/received: 1.7 GB / 1.0 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4 GHz Wireless network/SSID: BTHub5-Q8RK
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-Q8RK
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 90:72:82:97:0f:48
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
Sadly I can't use that speedtest I don't have a PC and the PS4 and my phone doesn't support flash player.
Message 4 of 9
I assume you're connecting wirelessly?
Message 5 of 9
Wireless or wired the connection drops and the modems light turns red.
Message 6 of 9
Anyone got an idea? Also when the Internet drops and I try access the modem settings it sometimes doesn't load, so thinking maybe a router error? But when I troubleshoot there's no problems.
Message 7 of 9
Message 8 of 9
Have you tried the quiet line test dial 17070 option 2 you should hear no noise if you can hear noise then it needs reporting to BT faults on 151 with no mention of broadband in the call
Message 9 of 9
Got rid of our house phone years ago, I'll try and see if I can get hold of one in the next few days. Everyone uses mobiles in my house.
Done some digging around Google using the errors in the Event Log. Seems I'm getting unusual activity from IP addresses from countries like Vietnam and USA. Non stop port forwarding disconnects. And sometimes I can't even load 192.168.1.254. and get obtaining up address hangings when trying to connect.
Even looked into setting a DNS server but the crappy HH5 doesn't allow such a thing..... And tried turning off UPnP which did jack all. Totally regretting going with BT, should of gone with Virgin....
