Proz
Message 1 of 8
Infinity 2 Slowing Down
Hi
I have had my infinity 2 for a month now .
At first all well and blistering speeds  95mbps down and 20mbps up.
Just at a months service now and ive got the speed drop.   Now down to 30mbps or less sometimes.
Just had an online chat with BT about it .
They tell me Ive never had 90+mpbs down lol .... and that its my BT Tv service downloading thats slowing it down...... sad fact is though is i dont have BT TV.
My IP Profile has halfed and this is whats slowing me down.
I do not use a BT Home HUB .
I use an ASUS DSL-AC68U which is a far superiour beast than any BT HUB.
I'll Put up some stats from the modem and hopefully someone can see something . Unfortuatly i restarted it hoping it would put my speed up again but i hasnt ... so its not been up for too long.
DSL UptimeDSL modulationAnnex modeSNR DownSNR UpLine Attenuation DownLine Attenuation UpPath ModeData Rate DownData Rate UpMAX Rate DownMAX Rate UpPOWER DownPOWER UpCRC DownCRC Up
0 days 0 hours 11 minutes 56 seconds
ITU G.993.2(VDSL2)
ANNEX_B
5.7 dB
15.4 dB
12.3 dB
4.0 dB
FastPath
65054 kbps
19999 kbps
78752
24012
13.5 dbm
7.1 dbm
12
0
1. Best Effort Test: -provides background information.
 Download Speed
 58.53 Mbps
0 Mbps62.97 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 58.53 Mbps
 For your connection, the acceptable range of speedsis 50.37 Mbps-62.97 Mbps .
 Additional Information:
 IP Profile for your line is - 62.97 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 16.18 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 16.18Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
I appreciate these figures may look good to some but i used to get the full 90+mb down but now its been reduced by a third .
7 REPLIES 7
Proz
Message 2 of 8
Re: Infinity 2 Slowing Down
WOW  .... super fast Infnity 2
http://www.speedtest.net/result/4138293213.png
imjolly
Message 3 of 8
With infinity 2 the max connection speed is 80mb with download a bit below that and what you are probably referring to is the max data rate which could be 80+ mb but that has no affect on your download speed
Proz
Message 4 of 8
Ok point taken ..... i did however always have 70 to 80+ mbps download speed using speedtest and BT wholesale site .
Now ive been slowed down by having my IP Profile slashed .... should i be happy with 17mbps ??? Would you be from 70+ ?
ray_dorset
Distinguished Guru
Message 5 of 8
Your IP profile is
Hardly slashed.
If not, I'll try again 🙂
Proz
Message 6 of 8
Its been slashed from 80+ to 62 .....
Anything actually useful to add ?
Proz
Message 7 of 8
Or is losing 15-20mbps acceptable to you ????
ray_dorset
Distinguished Guru
Message 8 of 8
Your SNRM is too low.
