Message 1 of 14
Infinity 2 Speed Reduced after switching to BT Smart Hub
Hi,
ive been on BT Infinity 2 for a few years now without any problems, and i was getting pretty much the full 76Mbps as the cabinet is literally at the end of my street, however i recently switched from my Netgear router to the BT Smart Hub with the intention of getting the BT TV package. After switching i noticed my speeds drop significantly so i tried plugging the Netgear router & BT Openreach Modem back in, but the speeds stayed the same
General browsing and online gaming still works fine, but when i download larger files, the difference is definitely noticable. I used to download in the regions of 7-8 MBps, however now it only goes at around 4-5 MBps. Before switching to the BT Smart Hub, i could download a movie from iTunes in around 10 minutes however last time i tried, it took over half an hour.
13 REPLIES 13
Recognised Expert
Message 2 of 14
Re: Infinity 2 Speed Reduced after switching to BT Smart Hub
Please post your full Home Hub router stats
Learn how from here Broadband Top Tips
Full router stats are key to any speed & connection issues.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 3 of 14
Product name: BT Hub 6A Serial number: +084319+NQ71591936 Firmware version: SG4B1000B316 Firmware updated: 31-Jul-2017 Board version: 1.0 Gui version: 1.64.0 DSL uptime: 0 Days, 3 Hours 48 Minutes 8 Seconds Data rate: 18.29 Mbps / 59.93 Mbps Maximum data rate: 18601 / 62907 Noise margin: 6.2 dB / 6.5 dB Line attenuation: 12.8 dB Signal attenuation: VPI / VCI: 0/38 Modulation: G_993_2_ANNEX_B Latency type: Fast Path Data sent / received: 92 MB Uploaded / 3549 MB Downloaded Broadband username: bthomehub@btbroadband.com BT Wi-fi: Active 2.4 GHz wireless network name: BTHub6-Q8H6 2.4 GHz wireless channel: Smart (Channel 6) 5 GHz wireless network name: BTHub6-Q8H6 5 GHz wireless channel: Smart (Channel 36) Wireless security: WPA2 (Recommended) Wireless mode: Mode 1 Firewall: On MAC address: F4:6B:EF:1D:10:A3 Software variant: - Boot loader: 7.33.1
Message 4 of 14
Product name:
BT Hub 6A
Serial number:
+084319+NQ71591936
Firmware version:
SG4B1000B316
Firmware updated:
31-Jul-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 3 Hours 54 Minutes 29 Seconds
Data rate:
Maximum data rate:
18601 / 62907
Noise margin:
6.2 dB / 6.5 dB
Line attenuation:
12.8 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Broadband username:
BT Wi-fi:
Active
BTHub6-Q8H6
Smart (Channel 6)
BTHub6-Q8H6
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:1D:10:A3
Software variant:
Boot loader:
7.33.1
Recognised Expert
Message 5 of 14
Try plugging your router into the hidden test socket that is revealed when you remove the bottom half of the split faceplate (2 screws) of your master socket. Only do this if you have a split faceplate. Do you have any extension sockets? Are there any wires connected to back of faceplate?
Post the router stats when plugged into test socket.
Try the BT Quiet Line Test (dial 17070 Opt 2), preferably with a corded phone, in the test socket with the router disconnected. If there is any noise, report to your landline provider as a voice fault (don't mention Broadband). Often sorting out voice faults will fix the Broadband as well.
Message 6 of 14
Ok i opened up the faceplate and tried connecting to the test socker, the results are below.
There were no extension sockets or wires connected to the back of the faceplate.
I also tried the BT Quiet Line Test with my phone plugged in and there was no noise.
Here are the router stats when plugged into test socket.  (I tried to format it properly this time so its easier to read)
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 0 Hours 3 Minutes 26 Seconds
Data rate: 18.14 Mbps / 60.69 Mbps
Maximum data rate: 18153 / 62442
Noise margin: 6 dB / 6.2 dB
Signal attenuation:
VPI / VCI: 0/38
Data sent / received: 1 MB Uploaded / 3 MB Downloaded
BT Wi-fi: Active
Firewall: On
Software variant: -
Boot loader: 7.33.1
Message 7 of 14
No reason you can’t use the Openreach mode and plug an Ethernet cable from that, into the red port on the smart hub.
That way the Modem will do the sync between the cab (which it seems it was better at, and ghe smart hub will be the router, and will work with BT TV.
Message 8 of 14
Slight snag, the smart hub doesn't have a red WAN port. Smiley Wink
Message 9 of 14
Yeah, it isn't that it's just slower at downloading larger files, the speed bounces up and down all the time ranging from 2MBps up to around 4 or 5 MBps.  When i had the Netgear router going into the Openreach Modem it was a solid 7-8MBps
Message 10 of 14
Does the Netgear not support Multicast/IGMP snooping/IPTV?
