Hi
Hope you can help me please.
I have enjoyed Infinity 2 now for well over 2 years (have 6 months to run apparently on my current contract) and have consistently had download speeds between 78 to 80Mbps. Just before Christmas however (and overnight) the speed dropped to 62 to 63Mbps. I've taken a week off work to do some jobs around the house, one of which was to get to the bottom of this. I've checked all my internal wiring and cannot find anything wrong. In an attempt to improve matters, I swapped out my HH5 for a Smart Hub (HH6) which BT provided last year but which I had not installed. This resulted in a further reduction to 57 to 58Mbps. This is measured using my download program which I use also to measure my speeds. Measurements using Speedtest.net are currently 52 to 53Mbps.
So after spending over 3 hours on the phone this week to try and get to the bottom of this, I have got absolutely nowhere. Managers are standing by the fact that I am over the so called minimum speed for my line, which they say is 53Mbps even though: - a. The up to speed is 76Mbps and b. I am over the minimum speed. They steadfastly refuse to investigate, at their expense which has made me angry at best. I have had a belly full of T & C's these days. I signed up for an "Up to" speed which up to before Christmas, I was enjoying. My line is more than capable of 76Mbps - they have confirmed this.
I want to complain at a very high level but would like to know if I'm wasting my time, given I'm over my contract's stated minimum, which I've never seen btw.
Any help would be most appreciated.
Probably just an increase in crosstalk, as more people are connected to the cabinet, there is not much you can do about it.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
If you have a BT Home Hub 6 (Smart Hub)
Please use this link to display the Smart hub (HH6) connection information
You will need to be connected to your home hub to do this.
Hi guys - thanks for your support.
Please see below the results as requested - hope they are posted correctly. The Quiet Line Test, was quiet: -
Product name:
BT Hub 6A
Serial number:
+084319+NQ63881880
Firmware version:
SG4B1000B522
Firmware updated:
01-Feb-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 5 Hours 19 Minutes 14 Seconds
Data rate:
20.00 Mbps / 58.01 Mbps
Maximum data rate:
24627 / 59176
Noise margin:
9.2 dB / 6.2 dB
Line attenuation:
16.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
132 MB Uploaded / 848 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-6F2C
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-6F2C-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
88:A6:C6:3C:94:41
Software variant:
Boot loader:
7.33.1
Hope this lot turns something up.
Many thanks once more
Still awaiting the DSL checker reults as pr links in both above posts.
Is this what you are referring to? : -
Telephone Number on Exchange is served by Cabinet 3
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate(Mbps) | Downstream Handback Threshold(Mbps) | WBC FTTC Availability Date | WBC SOGEA Availability Date | Left in Jumper |
High | Low | High | Low |
VDSL Range A (Clean) | 80 | 64.6 | 20 | 19 | 55 | Available | -- | -- | |
VDSL Range B (Impacted) | 77.8 | 50.7 | 20 | 15.5 | 39.8 | Available | -- | -- | |
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate(Mbps) | Downstream Range(Mbps) | WBC FTTP Availability Date | |||||
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | |||
ADSL Products | Downstream Line Rate(Mbps) | Upstream Line Rate(Mbps) | Downstream Range(Mbps) | Availability Date | Left in Jumper | ||||
WBC ADSL 2+ | Up to 12 | -- | 7 to 17 | Available | -- | -- | |||
WBC ADSL 2+ Annex M | Up to 12 | Up to 1 | 7 to 17 | Available | -- | -- | |||
ADSL Max | Up to 6.5 | -- | 5.5 to 8 | Available | -- | -- | |||
WBC Fixed Rate | 2 | -- | -- | Available | -- | -- | |||
Other Offerings | Availability Date | ||||||||
VDSL Multicast | -- | -- | -- | Available | -- | -- | |||
ADSL Multicast | -- | -- | -- | Available | -- | -- | |||
Premise environment | Status | ||||||||
Bridge Tap | N | ||||||||
VRI | N | ||||||||
NTEFaceplate | N | ||||||||
Last Test Date | 18-05-2017 |
from the checker the minimum handback speed is 55mb and you currently have a connection speed of 58mb so technically BT are correct but your speed is well below the checker estimated range
are you using the test socket with a filter even though you may currently be using a filtered master socket the test socket is where the engineer will connect to check your speed if you connect to test socket and have extension sockets elsewhere then check there is no dial tone all the extensions
try quiet line test dial 17070 option 2 should be quiet and best with corded phone
got to check basics first
I am sure your response is helpful but I don't really understand any of it - sorry. I said at the beginning of my 2nd post that thee Quiet line test was "quiet". Can you please explain the terminology please (jargon) in your post and then try and explain where I stand. After all I have had a reduction of 25% thrust upon me overnight. Managers refuse to investigate why and really I find this utterly preposterous.
the dslchecker results you posted after you allow for the bad formatting when posted shows the hand back (minimum) speed as 55mb but from your router stats you are cuuently on 58mb so above minimum hence why BT comments and not helping
connecting to the test socket which is normally behind the detachable bottom half of the master eliminates your internal wiring and the faceplate from causing any problems the test socket should be your best conenction
to check extension wiring you have to check that there is no dial tone at any extension socket while connected to test socket if any extension has a dial tone then there is a problem with your wiring
