Message 1 of 2
Infinity 2 - Speeds?
Heya!
I upgraded to infinity 2 on the 22/04/12, which took effect on midnight Tuesday 24th.
Since then the highest speeds have been 36.10 D/L & 20.30 U/L, obviously it have been adjusting over the 10 day period BT advise.
Over the last few days the speeds have been averaging 25 D/L & 18 U/L? These speeds apart from the U/L, are nowhere near the max of 76Mb that the profile allows?
Any ideas?
1 REPLY 1
Guru
Message 2 of 2
Re: Infinity 2 - Speeds?
Are you speedtests running wired or wirelessly? Could you run a speedtest here please? and post results http://www.speedtester.bt.com/
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
