FastShow
Message 61 of 62
Re: Infinity 2 activated, speeds vastly slower than estimates, only 1432kbps up!
OK, so quick update.  Things have been relatively stable with the Type A HH5, the DLM even disabled interleaving on the line and I was getting 49/14 D/U which I was happy enough with (even though I lost 4Mbps off of my upload for reasons I don't fully understand).
However, I today swapped to my Billion router and an unlocked HG612 so I can get some real stats for the line and use a router over which I have full control.  Weirdly I synched at 42/18, losing 7Mbps down (eek) but gaining 4Mbps up (yay?).  I seem to get a huge variation of sync speeds depending on which device I connect with and I don't know what's going on, does anyone else?  For the sake of reference, here are some nice stats and charts out the HG612 in case anyone can spot anything obvious:
xdslcmd info --pbParams
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 17855 Kbps, Downstream rate = 42404 Kbps
Path:	0, Upstream rate = 17876 Kbps, Downstream rate = 42276 Kbps
Discovery Phase (Initial) Band Plan
US: (0,95) (880,1195) (1984,2771)
DS: (32,859) (1216,1959) (2792,4083)
Medley Phase (Final) Band Plan
       VDSL Port Details       Upstream        Downstream
Attainable Net Data Rate:      17855 kbps         42404 kbps
Actual Aggregate Tx Power:        6.9 dBm          11.0 dBm
  VDSL Band Status	U0	U1	U2	U3	D1	D2	D3
  Line Attenuation(dB):	2.9	30.3	46.4	N/A	15.8	39.6	61.5
Signal Attenuation(dB):	2.9	30.2	46.2	N/A	15.8	39.6	N/A
        SNR Margin(dB):	6.0	6.0	6.0	N/A	6.1	6.0	N/A
         TX Power(dBm):	-3.7	-11.1	6.4	N/A	8.6	7.3	N/A
xdslcmd info --stats
Status: Showtime
Retrain Reason:	0
Max:	Upstream rate = 17875 Kbps, Downstream rate = 42404 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode
Trellis:		U: ON /D: ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 6.0		 6.0
Attn(dB):	 0.0		 0.0
Pwr(dBm):	 11.0		 6.9
			VDSL2 framing
			Path 0
B:		239		238
M:		1		1
T:		64		13
R:		0		16
S:		0.1807		0.4256
L:		10627		4793
D:		1		1
I:		240		255
N:		240		255
			Counters
			Path 0
OHF:		2389696		1002754
OHFErr:		69		12
RS:		0		732811
RSCorr:		0		129
RSUnCorr:	0		0
			Path 0
HEC:		94		0
OCD:		0		0
LCD:		0		0
Total Cells:	563396074		0
Data Cells:	1615388		0
Drop Cells:	0
Bit Errors:	0		0
ES:		53		12
SES:		0		0
UAS:		23		23
AS:		6935
			Path 0
INP:		0.00		0.00
PER:		2.89		6.91
delay:		0.00		0.00
OR:		66.41		23.13
Bitswap:	721		1
Total time = 1 hours 55 min 58 sec
FEC:		0		0
CRC:		69		0
ES:		53		12
SES:		0		0
UAS:		23		23
LOS:		0		0
LOF:		0		0
Signal attenuation (dB) 	U0	U1	U2	U3	D1	D2	D3
31 Mar 2015 12:43:00		2.9	30.3	46.4	N/A	15.8	39.6	61.5
I guess at this stage I'm trying to work out why my downstream varies by up to 10Mbps depending on which device I use, and my upload by 5Mbps or so, is this normal variation?
FastShow
Message 62 of 62
Realised I wasn't on the latest HG612 firmware so I updated, resynched and... lost nearly another 2Mbps off my upload. 😞  I just don't understand why things are so inconsistent and all over the place.
DSLAM/MSAN type:        	IFTN:0xb204 / v0xb204
Modem/router firmware:  	AnnexA version - A2pv6C038m.d24j
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:                 	10 min 5 sec
Resyncs:                	0 (since 31 Mar 2015 14:25:11)
				Downstream	Upstream
Line attenuation (dB):  	21.1		0.0
Signal attenuation (dB):	Not monitored
Connection speed (kbps):	42834		16191
SNR margin (dB):        	6.3		6.2
Power (dBm):            	11.1		7.0
Interleave depth:       	1		1
INP:                    	0		0
G.INP:                  	Not enabled
RSCorr/RS (%):          	N/A		0.0016
RSUnCorr/RS (%):        	N/A		0.0000
ES/hour:                	0		0
