bludigi
Message 1 of 2
Infinity 2 and HH3 woes
Hi,
I'm using BT Infinity 2 with a HH3.  At the moment the wireless signal on this HH3 is shocking, can't get anything higher than 70% even in the same room.  I've tried placing in different locations and changing wireless channels but to no avail.
The connection speed seems really slow.
1. Best Effort Test:  -provides background information.
 Download Speed
 27.68 Mbps
0 Mbps65.79 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 27.68 Mbps
 For your connection, the acceptable range of speedsis 12 Mbps-65.79 Mbps .
 Additional Information:
 IP Profile for your line is - 65.79 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 2.87 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 2.87Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Also, I am unable to open port 3074, even BT are unable to do it.  Rendering Xbox Live haphazzard at best.
Does anyone know what I can do?  If anything I'd like to go back to standard BT Infinity as that seemed far more stable.
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: Infinity 2 and HH3 woes
I would have thought that you were using the same HH3 as you were on normal Infinity connection, so nothing would have changed.
Wireless in general is not very reliable and there are better solutions, see
Network connection problems and possible solutions
Port forwarding is possible with the HH3, see the link at the bottom of this page Port forwarding problems
