Message 11 of 17
Re: VPN Issues
Oh, and I missed the second link, but I get the same issue with either an ECI or Huawei modem as I have both.
Expert
Message 12 of 17
Re: VPN Issues
Hi
I belive reading Rays helpful post its just the  HG612 ( Locked Version) that has the issue.
However Unlocked HG612 are not affected 🙂
Thanks Ray 🙂
Message 13 of 17
Re: VPN Issues
I think we may be on the right track though. I am going to try it with a Draytek 2860 this evening which has a VDSL modem built into it so I can take out the open reach modem from the equation completely.
Distinguished Guru
Message 14 of 17
Re: VPN Issues
IPSec VPN works fine here
If not, I'll try again 🙂
Message 15 of 17
Re: VPN Issues
Success.
Binned the BT modem and HH and replaced with a brand spanking new Draytek 2860. Configured the VDSL settings correctly and bingo everything connected. Now have a stable IPSEC connection (for the last 2 hours!!!) and everything is running as before.
So, looks like the modem firmware issue is still an issue.
Message 16 of 17
Re: VPN Issues
Update this morning - VPN connection stayed up with no drop outs for 12 hours. I am calling this a success
Expert
Message 17 of 17
Re: VPN Issues
Glad you got it sorted. 🙂
