We're in the process of ordering Infinity 2, and I was just wondering whether this system would require using microfilters on phone extensions in the house? we have 2 phones - one in the office, where the hub will be situated along with the new BT faceplace etc, and the other in the hallway. Would both of these phones require a microfilter?
Apologies if this question's been asked before.
Solved! Go to Solution.
No you should not need to use micro filters with infinity 2. The installer should change the master socket to a filtered one and that should do away with the need for filters on your extensions.
No you would not need microfilters anymore. The master socket will have two sockets, one for infinity and one for phone line or any phone extension cables.
Hi, I had Infinity Option1 installed yesterday but he didn't tell me to uplug my filters to my two phone extensions.
Its an Openreach MK2 mastersocket fitted.
I assume I can remove them for Option 1 as well...??
@fable wrote:
if the extensions are wired in to the mastersocket properly
If they are not it will only cause speed problems.
Actually you do need to use ADSL microfilters with BT Infinity on all the single socket phone extensions in your house. The engineer will install the main socket with 2 sockets and tthis does not require a microfilter. All the other sockets DO REQUIRE microfilters.
If you don't have microfilters installed then you will interupt the BT Infinity connection and youi'll also suffer from a loss of speed.
I've just had BT Infinty 2 installed and was told by the engineer that I didn't need microfilters. But my connection was broken every time I made a phone call. Spoke to BT and replaced the microfilters and everything is fine now, including much better speed.
Then yours was a bad install, and was not wired up correctly.
Filters are not needed on extensions if its been done properly.
