hongkongandy
Message 41 of 75
Re: Infinity 2 and still at 38 Meg
ladies, this handbags at 50 paces.
i have the same issue, 38 and no more.
what is the issue/ why no 76/
thanks hka
Deathtrap3000
Recognised Expert
Message 42 of 75
thanks hka
Have you upgraded to infinity 2? What are your predicted speeds?
hongkongandy
Message 43 of 75
If I upgrade I get unlimited use but still 38.......
my line doesnt suport more than 38 ????
How does that work?
Deathtrap3000
Recognised Expert
Message 44 of 75
How does that work?
So you havent upgraded? Are you just asking why you are predicted 38mbps?
hongkongandy
Message 45 of 75
I called BT to upgrade.........
They are more than willing to upgarde BUT
I will still only get 38 and no more the only beneficiat is unlimited use (which is not much use to me)
MY question was why can I not get 76 (ish)
Deathtrap3000
Recognised Expert
Message 46 of 75
Because you are too far from the street box to get full speed. The further you are from the street box, the slower your broadband gets. You may see an increase if the estimate was off.
Topham
Message 47 of 75
This is why i dont see how i can only get 38 as my Street box is under 100m away.
Deathtrap3000
Recognised Expert
Message 48 of 75
You should be able to get more. There is something wrong with your line as its still configured for infinity 1 and the mods are trying to sort it out.
Moderator-Retired
Message 49 of 75
I have explained the situation to you in the email I sent a few days ago - if you have any questions or are still unsure about what I mean please reply to it. You aren't on BT Infinity 2; you're on BT Infinity (1), Option 2. Your line profile/stats/usage/etc. is 100% correct.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
ptan
Message 50 of 75
Hi topham
Just one thing, if you go onto the BT.COM website and go to the "Broadband Speedchecker" what does it estimate your speeds to be? Irrespective of what you are on at the moment, it should still show what BT are estimating what your line possibly is capable of.
ptan
