robbiemore123
Message 1 of 6
Infinity 2 capped at 40Mb??
Hi,
I am trying to get to the bottom of why my Infinity 2 connection is seemingly 'capped' and running at Infinity 1 speed.
I have opened a fault with BT through online chat, and their initial diagnosis was a dodgy HH6, which I have received a replacement for, and as I expected hasn't cured the problem.
Looking through other posts, I have run  BT Broadband Availabilty Checker, and got the following results:
VDSL Range A (Clean)8076.32020--Available----
VDSL Range B (Impacted)80552016.9--Available----
WBC ADSL 2+Up to 11--8.5 to 13Available--Yes
WBC ADSL 2+ Annex MUp to 11Up to 18.5 to 13Available--Yes
ADSL MaxUp to 8--7 to 8Available----
WBC Fixed Rate2----Available--Yes
Fixed Rate2----Available----
And from my HH6 diagnostics:
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B10002236
Firmware updated:
02-Nov-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 4 Hours 19 Minutes 19 Seconds
Data rate:
12.00 kbps / 40.00 kbps
Maximum data rate:
32362 / 87489
Noise margin:
19.7 / 20.6
Line attenuation:
12.9
Signal attenuation:
Actual speeds are 35/11. MyBT definitely says Infinity 2.
Even more frustrating is that I have a second line/fibre connection at home provided by SSE/Daisy Communications which is running at 76/20 without fail.....
Any ideas anyone???
5 REPLIES 5
Webby
Message 2 of 6
Re: Infinity 2 capped at 40Mb??
It's likeley you're on a banded profile due to a problematic connection.
The fact you're upstream is syncing above the 10meg that would be limited on a 40/10 or a 55/10 all but confirms you're on an 80/20 service but banded.
Have tou had a dropping connection historically?
Are you connected to the test socket?
pippincp
Message 3 of 6
@Webby I think you meant 80/20.
Webby
Message 4 of 6
Hehe yes of course that's a typo 🙂
robbiemore123
Message 5 of 6
Thanks @Webby
Yes it seems it does occasionally disconnect.
I'll try connecting to the test socket.
Have also noticed that the phone line is noisy (don't ever use the phone itself...)
Webby
Message 6 of 6
If you have a noisy line call 151 and report a fault. I can almost guarantee that'll be the cause of your dropping connection and as a result, your line being banded.
