MandG
Message 1 of 12
Infinity 2 constant disconnections and HUGE speed drop
Recently we have suffered a lot of disconnections which has lead to a massive speed drop.
When the engineer installed he said we were so close to the cabinet we should get amazing speeds which we always have (79/19)
cheers
3. Firmware version:Software version 4.7.5.1.83.8.222.1.1 (Type A) Last updated 19/02/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 21:07:53
6. Data rate:2344 / 23830
7. Maximum data rate:2517 / 24445
8. Noise margin:5.1 / 5.8
9. Line attenuation:36.9 / 29.9
10. Signal attenuation:29.5 / 32.5
11 REPLIES 11
pippincp
Message 2 of 12
Re: Infinity 2 constant disconnections and HUGE speed drop
A lot of disconnections would cause DLM to step in and attempt to stablise your line. As long as the line remains stable your speed should creep back up.
Try a quiet line test with a corded phone, 17070 option 2. Any noise report as a line fault not a broadband one.
MandG
Message 3 of 12
Cheers looks like i'll have to go and buy a phone as we don't use one.
pippincp
Message 4 of 12
You can pick one up for about £5 from a well known catalogue shop.
MandG
Message 5 of 12
Ok BT sent me a new home hub 5
Im now stuck on a seriously low speed even after about 10 days?
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated Unknown
5. DSL uptime:0 days, 10:46:49
6. Data rate:14272 / 21412
7. Maximum data rate:17096 / 26856
8. Noise margin:5.7 / 7.9
9. Line attenuation:39.1 / 32.3
10. Signal attenuation:33.4 / 34.3
Keith_Beddoe
Message 6 of 12
Did you try a phone to see if there was any noise on the line?
Try connecting things up as shown below, and see if the connection speed improves.
Also, make sure your internal wiring is correct.
Webby
Message 7 of 12
Something definitely isn't right. The max attainable speed is less than half the minimum expected speed.
Carry out the test socket check and we'll take it from there.
MandG
Message 8 of 12
I've got one of the open reach sockets that doesn't need a filter and I don't have anot extension.
I'll have to go buy a phone by the looks of it
MandG
Message 9 of 12
Bought a phone today and either the phone is a dud or the line is dead?
licquorice
Message 10 of 12
I suspect you are only working on one wire, broadband will sometimes work on just one but the phone needs both wires. If the phone is dead at the test socket you need an engineer visit.
