Distinguished Guru
Message 21 of 25
Re: Infinity 2 installed today, underwhelmed by speed
What exchange are you connected to?
If not, I'll try again 🙂
Message 22 of 25
As in what equipment is in there or where? As far as I know its Gynn Square in Blackpool....
Distinguished Guru
Message 23 of 25
I think your exchange is North Shore but I can't see any reports of congestion
Expert
Message 24 of 25
Are you just using one computer to test your speeds? If you use another computer it would rule out the computer as the problem
Message 25 of 25
Yes Gynn Square is North Shore, and i have used two computers and my xbox one all wired to test and each one gives similar results. Thanks for everyones help so far, just a bit miffed so far!
