VictorSegura
Message 1 of 8
Infinity 2 - slow with high noise level
Hi
I have had Infinity 2 installed for a couple of days but only get received the Smarthub.  The estimated speed was 52mb but unfortunately I have only been achieveing between 2 and 10.  Having looked at the diagnostics I think that noise margin might be an issue.  Does anyone have any ideas?
Product name:
BT Hub 6A
Serial number:
+084316+NQ73260367
Firmware version:
SG4B10002244
Firmware updated:
19-Oct-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 1 Hours 23 Minutes 57 Seconds
Data rate:
10.00 kbps / 55.00 kbps
Maximum data rate:
42347 / 109493
Noise margin:
30.7 / 22.1
Line attenuation:
10.7
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
154 MB Uploaded / 2170 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-ZH5M
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-ZH5M-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Band steering:
Off
Wireless mode:
Mode 1
Firewall:
On
MAC address:
58:90:43:0A:C6:A9
Software variant:
Boot loader:
7.33.1
7 REPLIES 7
VictorSegura
Message 2 of 8
Re: Infinity 2 - slow with high noise level
The BT Wholesale check gives this:
pippincp
Sage
Message 3 of 8
How are you testing your speed? According to your hub stats you are getting 55Mb.
Are you sure you are on Infinity 2 as those stats look perfect for Infinity 1.
Enter your phone number HERE once the first test has finished scroll down and click on Further Diagnostics and post a screenshot of the result. Remove your number before posting.
john46
Message 4 of 8
I fully agree looks like Infinity 1
XRaySpeX
Recognised Expert
Message 5 of 8
Are you saying that that router reports Meg as Kilo? Which HHs do that?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
pippincp
Sage
Message 6 of 8
Only the (Notso)Smart hub. It's a firmware bug.
imjolly
Message 7 of 8
the data rate will be corrected in the firmware update which your hub is still to receive - new firmware ends 316
pippincp
Sage
Message 8 of 8
You are of course correct @imjolly and I'm kicking myself for not mentioning it.Smiley Embarassed
