Message 1 of 3
Infinity 2 speed
Hi I signed up to infinity 2 13 days ago and I am not getting the speed I was told I would get I.E 52-69
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ72795890
Firmware version:
SG4B1000B316
Firmware updated:
29-Sep-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
12 Days, 12 Hours 13 Minutes 58 Seconds
Data rate:
10.98 Mbps / 46.69 Mbps
Maximum data rate:
11321 / 53831
Noise margin:
6.2 dB / 5.4 dB
Line attenuation:
21.4 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
8258 MB Uploaded / 30736 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-TW82
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-TW82
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
B8:EE:0E:FB:16:CB
Software variant:
Boot loader:
7.33.1
From BT availability Checker
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
Premise environment
Status
VDSL Range A (Clean)69.351.32015.944Available--YesYes--
VDSL Range B (Impacted)56.432.418.58.627.4Available--YesYes--
FTTP on Demand33030--Available--------
WBC ADSL 2+Up to 4.5--3.5 to 5.5Available--------
WBC ADSL 2+ Annex MUp to 4.5Up to 0.53.5 to 5.5Available--------
ADSL MaxUp to 4.5--3.5 to 5.5Available--------
WBC Fixed Rate1 ----Available--------
VDSL Multicast------Available--------
ADSL Multicast------Available--------
Bridge TapU
VRI--
NTEFaceplate--
Last Test Date19-05-2017
2 REPLIES 2
Message 2 of 3
Re: Infinity 2 speed
are you using the test socket with a filter to eliminate your home wiring and see if that improves your conenction speed?
with the stats posted you should drop to infinity 1 especially as BT are in process of improving infinity 1 speed to 80/20mb free
Message 3 of 3
I have just joined BT and was connected on 28/09/2017 and was advised that infinity 2 was the best option for me so I dont think that I can downgrade to infinity 1 at the moment.
There are no extensions on the master socket  I.E take the faceplate off and there is nothing connected to it.
I should add that I was an EO line until a about 3 weeks ago and the cabinet I'm connected to ( 12) is about 200 yards as the crow flys I know that the line length is much longer.
So it looks as though im stuck with this speed for 12 mths
