Message 1 of 2
Infinity 2 - speedtester.bt.com vs others
Is there any reason that I would get significant better results using the speedtester.bt.com as oppossed to any of the others  - broadbandchoices.co.uk , speedtest.net etc ?
With speedtester.bt I can get 71.6 mb download - all the others report around the 26 mb mark - many thanks.
1 REPLY 1
Message 2 of 2
Re: Infinity 2 - speedtester.bt.com vs others
it vary from server to server , just pick a differant download location on speedtest . net and youll get a differant result. Personally i always beleive the highest one ;0)
theres always here http://www.speedtester.bt.com/beta/speedtest-remote.jsp at least with that one you can be sure your getting a more accurate result after a few tests because its always using the same location
