andrewk
Message 21 of 49
Re: Infinity 2 stabilisation period - how can I tell it is happening?
Thanks for that ....... there doesn't seem to be any other way, does there?
infinidim
Expert
Message 22 of 49
Sorry, no.
Infinidim
Megadodo Publications
Ursa Minor Beta
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side
If the the reply answers your question then please mark as ’Mark as Accepted Solution’
andrewk
Message 23 of 49
FWIW, I ran the BTW speed test and diagnostic this morning.    D/L speed is 37.67Mbps (profile 38.72Mbps) and U/L speed is 6.42 Mbps (profile 10 Mbps).   This is almost exactly what is has been since I originally signed up to Infinity 1 nearly 2 years ago.  (apart from the very occasional glitch).
It's not so much that I am unhappy with the speeds I am getting, but that the upgrade for Infinity 2 seems not to have  been done, even though it is recorded as being complete on BT's computer systems and on the order tracking page.
Andrew
john46
Message 24 of 49
what speed were you estimated when you upgraded to option 2
andrewk
Message 25 of 49
45Mbps
john46
Message 26 of 49
ok just wait for the mods to contact you
andrewk
Message 27 of 49
I'm waiting .....
Andrew
infinidim
Expert
Message 28 of 49
@andrewk wrote:
I'm waiting .....
Andrew
Andrew, I know that the mods are currently very busy so it might take a bit of extra time to get back to you. It might be worth contacting them again quoting the reference number that you got when you first contacted them and asking how things are going in resolving this issue.
Infinidim
Ursa Minor Beta
andrewk
Message 29 of 49
Done - awaiting response
Andrew
infinidim
Expert
Message 30 of 49
Andrew
Andrew, I hope that things now move forward for you. Keep us updated please.
Infinidim
Ursa Minor Beta
