Newbie
Message 1 of 3
Infinity 2 sudden speed drop!
I have had infinity 2 for over a year where I have regularly checked the speed which has been a constant 72mbps download & 17mbps upload. However 5 days ago my download speed dropped to 60mbps and my upload speed has not changed. I contacted the customer services and was told to reset my modem after 48 hours. There has been no change since the reset. There must be a reason for this sudden drop and I would appreciate help in how I can get my original download speed back.
2 REPLIES 2
Message 2 of 3
Re: Infinity 2 sudden speed drop!
Hi
The most likely reason your speed has dropped is because of a noise /crosstalk issue this has caused the DLM to reduce your IP profile to stabilise the line all you need to do is leave the connection alone for up to 2 weeks and once the DLM see the line as stable again it should start to rise again
Newbie
Message 3 of 3
Hi, thank you for your reply. Should I try resetting my modem or just leave it as there is conflicting answers on this point.
