Bc1973
Message 1 of 3
Infinity, BT Vision & Apple Airport Extreme
Hi all. I've been having an on-going issue with my Home Hub 3 and Apple TV setup but a colleague at work may have offered me a solution in the form of an Airport Express. He doesn't use BT but is technically minded and he reckons that the Airport will replace the Home Hub 3 and fix my issue. What he's unsure of however, is whether it will work with Infinity (I was about to upgrade) and BT Vision. Does anyone know if it does?
2 REPLIES 2
Message 2 of 3
Re: Infinity, BT Vision & Apple Airport Extreme
Yes it will. Have a search for it, there's been a couple of threads on it recently.
Moderator-Retired
Message 3 of 3
Hi Bc1973,
I've moved your thread to the Infinity board as you might have more success in getting a reply from Infinity users here who have been in your situation and have found a solution.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
