Reefman
Newbie
Message 1 of 2
Infinity Broadband speed dropped to same level (1.5) before infinity installed!
My infinity broadband speed seems to have reverted to a similar speed i had before infinity was installed. Seems to have happened in last 24 hours. Nothing has changed on my end - everything is exactly as it was when installed.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Infinity Broadband speed dropped to same level (1.5) before infinity installed!
Hi Reefman,
Please could you run a speed test using www.speedtester.bt.com once you have done so, please could you drop me an email with your BT details and a link to this thread? My email address can be found by clicking on my profile.
Paddy
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
