gillis40
Message 1 of 8
Infinity Option 1 Speeds
Had my Bt Infinity Installed 2 days ago......
Was told that my download speed should be 40mb and upload should be 10mb...
Ive done the checker whilst wired up... (Im feeling wired up at the moment....!!)   lots of times and im getting ...
download between 7 and 10mb
upload between 5 & 6mb
Ping ranges between 45 and 167
wireless is useless it keeps dropping and connecting ive tried changing channels and still its useless....
Any ideas....?
Also did a line check and nothing came up there....!
7 REPLIES 7
Bullitt
Distinguished Expert
Message 2 of 8
Re: Infinity Option 1 Speeds
what is your ip profile?
john46
Message 3 of 8
are you connecting by wireless or ethernet cable when you ran the speed test as the test should be done with a wired connection
gillis40
Message 4 of 8
sorry for the stupid question.....but how do I find out what my ip profile is....?
gillis40
Message 5 of 8
I ran it 5 times over the past 2 days with the ethernet cable...!  Havent tried to run it without...
sjtp
Guru
Message 6 of 8
Not a stupid question; we take too much for granted ... To find your profile
Either http://speedtester.bt.com/ and choose the ‘ADSL and Fibre diagnostics’ option
or Tom’s BRAS checker http://windows.mouselike.org/be/?DoAction=BrasChecker which isn’t a speedtest but gives profile.
(people who post 'what is your ip profile?' should add this to their post)
Bullitt
Message 7 of 8
have you noticed that the time the bras checker takes is about the same time it takes to run a speedtester?
sjtp
Guru
Message 8 of 8
have you noticed that the time the bras checker takes is about the same time it takes to run a speedtester?  I hadn't noticed that.  I tend to start them and get on with something else in another tab.  Just doing some timings as a matter of interest, though ...
I prefer the bras check for a few reasons
  1. The bras checker telephone number field is remembered by Chrome, but for some reason it does not remember the field in the BT checker.   (Firefox remembers both).
  2. It does not rely on Java.  I've nothing against Java and use it quite a bit, but there have been hiccups for a lot of people (including me) with Java 7 and the BT checker.
  3. Every now and then, even though I choose the right 'ADSL ... Diagnostics' option in the BT checker, it comes back with a speedtest but no profile.
