halestone
Message 1 of 10
Infinity Role out phase 9a
My Cabinet is showing the information below. Does anyone know when phase 9a is ?
P150100%4.19aPart of deploymentFTTC (Fiber to the Cabinet)
9 REPLIES 9
Aarong
Guru
Message 2 of 10
Re: Infinity Role out phase 9a
Sometime next year, could be March i think.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Danimak
Message 3 of 10
Where do you get that info from???
halestone
Message 4 of 10
http://fttc-check.alc.im/
The above for info on your cabinet. Don't put any spaces when entering post code.
I have read that there is list somewhere showing possible start dates for phases. Anyone know how to get a look it.
Ps thanks for the date.
Danimak
Message 5 of 10
What does it mean by 6b?
Aarong
Guru
Message 6 of 10
@Danimak wrote:
Rollout phase for fibre to your postcode, doesn't include cabinet deployment though.
Danimak
Message 7 of 10
Yeah i get that bit. is there not a date attached to that "6b" phase?
Aarong
Guru
Message 8 of 10
No there isn't but thinking 6b was last December.
lukeool
Message 9 of 10
Any one know when 5b might be rolling out?
RichRolls
Message 10 of 10
We were on Phase 7a, and it went live in early April 2012.
I don't know whether the pahases are sequential, date wise, though.
Rich
If you found this information helpful, please click the star to the left of this post. If the reply answers your question then please mark as ’Mark as Accepted Solution’
