ggbrown73
Message 1 of 8
Infinity Speed Dropping gradually.
Hi,
I have had BT Infinity now for about a year and thus far have been happy enough. Initial speeds were about 50mb(ish) download and 6mb(ish) upload. Over time my speeds have gradually dropped to what I think is unaceptable speeds.
The last few nights it has been between 10-12mb down and less than 0.5mb upload. I tested it today and it is 26mb up and .3mb down.
Can anything be done to speed up the service again?
Thanks in advance.
7 REPLIES 7
imjolly
Message 2 of 8
Re: Infinity Speed Dropping gradually.
go to your hub if hh5 then troubleshooting then helpdesk and post 1-12
run btspeedtster and when first test completes then run diagnostic test and post results  MUST be done wired
btspeedtester
enter your phone number and post results  remember to delete number
https://www.btwholesale.com/includes/adsl/main.html
ggbrown73
Message 3 of 8
Thanks for the prompt reply. As requested: Results from Spped Test -
From Exchange Connection speed42.6Mb
Good
  • Download speed 29.7Mb
  • Upload speed 0.69Mb
1. Product name:BT Home Hub
2. Serial number:+068343+NQ40137392
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 07/07/15
4. Board version:BT Hub 5A
5. DSL uptime:9 days, 05:38:52
6. Data rate:769 / 42743
7. Maximum data rate:773 / 42717
8. Noise margin:6.2 / 6.1
9. Line attenuation:35.2 / 23.6
10. Signal attenuation:7.6 / 21.3
11. Data sent/received:7.4 GB / 123.1 GB
12. Broadband username:bthomehub@btbroadband.com
DavidM
Moderator
Moderator
Message 4 of 8
Hi ggbrown73,
As imjolly has mentioned was this test run via wireless or cable? If it was wireless can you try again via cable connection?
Cheers
David
ggbrown73
Message 5 of 8
Hi,
wirless was switched off and it was run with the cable attached.
ggbrown73
Message 6 of 8
Hello, anyone able to help at all?
imjolly
Message 7 of 8
can you post current router stats and also run btspeedtester and when first test completes then run diagnostic test and post results - must be done with wired conenction
btspeedtester
ggbrown73
Message 8 of 8
Thanks,
unplugged the hh5 and left it for a few minutes. Now getting 38.6d and 5.81u. Happy enough with that.
Cheers.
