pintosal
Message 1 of 4
Infinity Speed Expectations
On Tuesday afternoon this week I had Infinity installed, and the engineer ran a speed test. The result was a pleasing 32Mb/s, up from 4Mb/s on the ADSL+ Last night at around 10pm I noticed that web browsing performance had deteriorated. It felt slower than when I was on the ADSL. I ran the speed test a couple of times, and it varied between 9Mb/s down to 2.5Mb/s. Is this to be expected? My understanding is that BT prioritise web browsing traffic, and so performance should not be impacted. Is there a network problem, or are my expectations unrealistic?
3 REPLIES 3
imjolly
Message 2 of 4
Re: Infinity Speed Expectations
I suggest you post your problem on the infinity board and probably get more replies
robh66
Message 3 of 4
You've still got the 10 day stabilising period to get through, so the slowdown should be expected. But monitor it and if after 10 you run a speedtest  at www.speedtester.bt.com. And it still shows your download speed as slower than your old ADSL2, then get in touch with the help desk in India.
toekneem
Distinguished Guru
Message 4 of 4
Hi pintosal.
As its a new activation your line speed can vary while is is looking for the best stable speed.
How do you connect, is it wired or wireless.
Also can you do a BT speedtest  awired if possible and post the results with the IP profile for your line.
[edit] I will ask the mods to move your post to the Infinity forum,
toekneem
(EASBF)
