Open reach recently fixed my line, i originally had great speeds of 51meg the line speed did drop a little after 2 years to 46. The line speed is now stuck at 36meg, Bt are saying there is nothing they can do. Open reach came 2 weeks ago and they said the line would be reset but i dont think it has been done. Im wondering if a moderator could look in this for me.
thanks
Solved! Go to Solution.
Can you post the connection stats from the hub?
HH5 Troubleshooting/helpdesk
HH6 Advanced settings/technical log.
thanks
Looks like DLM has banded your line at 44M due to the line fault, the engineer obviously didn't arrange a reset. It will take a bit longer for DLM to relent but it will do so eventually.
Thanks a lot for your help.
HI,
im wondering if someone could look at my line the sync speed is still stuck after 8 weeks no sign of it returning back to what it was.
The hub stays connected for 2 weeks or more.
help would be appreciated
Repost the connection stats please.
