adamsmessages
Message 1 of 16
Infinity Upgrade Issue-IP profile not updating
Is anybody having issues upgrading from standard broadband to Infinity? I was due to upgrade on 17/10. Order showing as complete and I have gone through the 10 day stabilsation period but IP profile stuck around 3Mbps. Speed should be a minmum now of 22Mbps. Completed all the standard tests with the BT fault team but going round in circles.
Can any one suggest any hub settings I can check/change myself? Can I request the IP Profile to be reset- or is it just a waiting game?
It is a shame the BT customer service team doesn't keep the order open until they have tested and confirmed that the upgrade is working correctly- just a thought BT.
15 REPLIES 15
gg30340
Message 2 of 16
Re: Infinity Upgrade Issue-IP profile not updating
It should have happened right away.
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then scroll down the page and carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If you have a Homehub 5 can you post the stats by logging onto the Homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
or
If you have the Smart Hub, (Homehub 6) can you go to hub manager then advanced then technical log and post the stats. http://bthomehub.home/
john46
Message 3 of 16
if you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
john46
Message 4 of 16
there are no settings you can change also your IP Profile is set by your connection speed and cannot be reset by BT also there is no longer a 10 day stabilisation period your speed on the first day is the speed you achieve
have you tried connecting the hub to the test socket with a new filter
adamsmessages
Message 5 of 16
adamsmessages
Message 6 of 16
Thank you for your replies. I have started to post the inofrmation requested. In answer to your question, yes filter changed- but not test socket behind the faceplate of main double socket.
Any particular stats required from the homehub 6?
john46
Message 7 of 16
does you socket look like this infinity socket.jpgor this Test Socket.jpgif like the top picture you do noty need a filter and your hub should be connected to the top socket and your phone to the lower one
john46
Message 8 of 16
yes the information The stats for the Home Hub 6 can be found on the Information page from http://192.168.1.254 then Advanced Settings -> Technical Log.
adamsmessages
Message 9 of 16
No, its a standard BT double telephone socket. (I have tested both sockets)
adamsmessages
Message 10 of 16
