tyland
Message 1 of 2
Infinity Upgrade
Engineer coming Friday but Bt e-mailed that equipment being sent. Unlikely that I will be in to receive but is there anything of importance given that I already have the Home Hub 3?
1 REPLY 1
gg30340
Message 2 of 2
Re: Infinity Upgrade
It could be that they are sending you an Ethernet cable to connect the homehub to the Openreach modem that the engineer will bring and possibly an Homehub to replace the one you have, although this is more unlikely than likely as the blurb about Infinity states that if you have a homehub it won't be replaced.
